[GRADE A] AUNE S10N Streamer WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black
-16%
Refurbished product - Grade A
The S10N represents the next generation of Aune streamer, adopting an architecture based on five core: NXP Freescale™ processor, MediaTek™ WiFi streamer, LDAC / aptX HD Bluetooth receiver, PLL clock and asynchronous FPGA. A quality structure perfectly optimized to deliver high fidelity sound reproduction, both locally and wirelessly. And if the performance is there, the S10N is not left behind on the functionality side and will meet the vast majority of needs.
Reduced price!
Reference : 18216
Refurbished
Limited special offer
699,00 €tax incl.
-16%
589,00 €tax incl.
490,84 € tax excl.
Product in perfect condition. Torn / damaged cardboard box.
Aune S10N
Aune S10N Lecteur réseau WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Noir
Aune S10N Lecteur réseau WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Noir Aune S10N Lecteur réseau WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Noir
MediaTek streamer & Control app
As a central element of this Aune S10N, the section in charge of WiFi network playback uses a MediaTek™ controller. This one allows a stable and fast broadcast of the audio stream. The S10N is also extremely easy to control remotely using the free iEast mobile app, available on both Android and iOS. The latter allows easy interaction with your device, via an ergonomic and intuitive graphical interface.
ARM Cortex-M7 Processor
The S10N is powered by a powerful ARM Cortex-M7 processor, ensuring fast and reliable data processing but also in charge of hardware decoding of audio streams. It allows the reading of high resolution files, up to PCM 32bit 768kHz and DSD512, ensuring a formidable sound precision.
Bluetooth HD Qualcomm QCC5125 receiver
In addition to its WiFi network connectivity, the Aune S10N is equipped with a Bluetooth 5.0 receiver. It incorporates a Qualcomm QCC5125 chip for high-quality wireless audio transmission, including support for aptX, aptX HD and LDAC codecs.
PLL Clock
The S10N's complex PLL clock provides a highly accurate signal. This signal is then fed to the asynchronous FPGA to generate ultra-low jitter digital signals for the most transparent and faithful sound possible. The S10N also allows the use of an external clock through its 10M input.
Asynchronous FPGA
After decoding the audio stream, the ARM processor passes the signal to the FPGA and its oscillators. The FPGA then uses its own algorithm to regenerate the digital signals with extremely low jitter and provide a signal of absolute precision.
Power supply
Pour fournir un signal électrique propre et stable à ses différents circuits, l'Aune S10N s'appuie sur un étage d'alimentation avec deux transformateurs à faible bruit et des régulateurs de tension à faible ondulation.
File reader
A network player but also a file player, the Aune S10N offers two USB-A ports to connect USB storage devices up to 2TB (not included). An additional way to access your music for maximum versatility.
1Previous
2Play/Pause/OK
3Next
4IR receiver
5Screen
6ON/OFF LED indicator
710M clock input
8Coaxial output
9Bluetooth antenna
10WiFi antenna
11Balanced XLR output
12Single-ended RCA output
13I2S HDMI output
14AES/EBU output
15Optical Toslink output
16USB-A inputs
17Power button
18Power input
Product typeStreamer
InputsBluetooth 5.0
WiFi 2.4G
2* USB-A
1* 10M clock input on BNC connector
Outputs1* Balanced stereo XLR
1* Single-ended stereo RCA
1* I2S via HDMI
1* AES/EBU
1* Coaxial
1* Optical Toslink
ConnectivityWiFi 2.4G
Bluetooth 5.0
Supported sampling ratesI2S / RCA: PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial / AES: PCM up to 32bit 384kHz, DSD DoP up to DSD128
Optial: PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N (digital output)-147.6dB
Jitter (digital output)181ps (700Hz-100kHz)
Frequency response (analog output)20Hz-20kHz ±0.5dB
Output level (analog output)4.39µV
Noise floor (analog output)0.00068%
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Dimensions288*211*63mm
Analog output:
Digital output:
I2S pinout:
InputWiFi
OutputCoaxial SPDIF
OutputAES/EBU
OutputOptical Toslink
OutputI2S
DAC / ADC ChipNC
Max sampling rateDSD512
Max sampling rate768kHz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Refurbished GradeGrade A
Refurbished product - Grade A The S10N represents the next generation of Aune streamer, adopting an architecture based on five core: NXP...
