Refurbished product - Grade A
Product in perfect condition. Cardboard packaging damaged.
Gustard's P16 is an advanced preamplifier / volume controller / souce selector (3 Inputs). It will delight audiophiles looking for a fully balanced circuit with volume control to drive a power amplifier in any demanding audio system.
It offers an innovative option to configure separately the input gain from the output gain. This is a particularly useful feature that allows operation even with devices that have very different specifications.
This preamplifier has a circuit designed for fully balanced applications. Thus the inputs, the volume control, the preamplification stage are all fully balanced with no conversion stage at all.
It uses two high-performance stereo LME49860 operational-amplifiers. The amplification stage is hybrid, that is to say it relies on OPA as well as discrete components subcircuits.
The output stages are constructed from discrete components with differential signaling architecture, which ensures excellent stability in output signal.
Thanks to a relay matrix driven by a logic circuit ALTERA MAX, the P16 is able to provide a constant and accurate volume on each channel.
This type volume of control combines the best of both worlds with : the precision and finesse of pure analog attenuation as well as the confort of digital control and the ability to change the volume remotely.
Gustard P26 carry its own linear regulated power supply with high speed low noise rectifier.
It also benefits from a custom ultra-low noise discrete voltage regulator .
The power supply finally uses a 50W toroidal transformer specifically developed for properly supplying this circuit.
A selector on the back of the unit toggles between 230V / 110V power-grids.
The P26 comes with an infrared remote control. This remote enables the user to access the volume, mute and source selection functions.
WARNING: In order to operate the remote control, please press and hold the AMP button on the remote control for 4 seconds.
All control are also available on the front panel. An ON / OFF button, a control button to select the source and configure the input / output gain. Finally, a rotary controller is used to adjust the volume level.
The OLED monitor screen shows real-time the active source, the current volume level and the in / out gain parameters.
A | Unbalanced RCA output |
B | Balanced XLR output |
C | Balanced XLR Input 2 |
D | Balanced XLR Input 2 |
E | Unbalanced RCA Input |
F | 230V/110V selector |
G | IEC Socket (AC IN) |
P16 has two balanced inputs on XLR stereo ports and one unbalanced input (stereo RCA).
one RCA stereo output and one XLR stereo output are used to connect the P26 to a balanced or unbalanced amplifier.
Type | Preamplifier Volume Control |
Gain Control | Independent input gain / output gain control |
Output impedance | XLR: 100Ω RCA: 100Ω |
Maximum Output Level | RCA: 9.5Vrms XLR: 19Vrms (+ dBu) |
Class | AC 115V / 230V 50 / 60Hz (manual adjustment). |
AOP | 2x dual op amp LM49860 |
Inputs | Balanced XLR x 2 Unbalanced RCA x1 |
Outputs | Balanced XLR x1 Unbalanced RCA x1 |
THD + N | < 0.00035% 20-22kHzBW @ 18dBu (gain In) 18dBu (gain Out) |
Channel crosstalk | -130dB @ 20-20KHz |
SNR | 130dB |
Frequency response | 20-20KHz /+-0.1dB |
Remote control | Yes |
Power consumption | Less than 20W |
Power supply | AC 115V / 230V 50 / 60Hz (manual adjustment). |
Dimensions | Width 330 x Length 260 x Height 65mm |
Input | XLR |
Input | RCA |
Output | RCA |
Output | XLR |
Color | Black |
Class | Class A / AB |
Remote Control | Yes |
Refurbished Grade | Grade A |
