[GRADE A] IEAST SOUNDSTREAM PRO M30 Media Player UPNP USB DLNA AirPlay Wifi RJ45 Multiroom ES9023
-18%
Refurbished product  - Grade A
This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly from your Smartphone, tablet, computer, or other DLNA / AirPlay / UPnP compatible source.
Reduced price!
Reference : 18013
Limited special offer
139,00 €tax incl.
-18%
114,00 €tax incl.
95,00 € tax excl.
Box slightly damaged. Very slight marks on the edges of the product.
This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly from your Smartphone, tablet, computer, or other DLNA / AirPlay / UPnP compatible source. The iEast receiver has WPS technology, allowing you to connect to the WiFi network in a simple, fast and secure way. The WPS button on the case allows you to access this option. You can also connect it via its RJ45 Ethernet port, free to choose according to your preferences.
With a 3.5mm Stereo Jack and a Toslink Optical Output, you can easily connect it to your HiFi or audio amplifier to listen to music up to 24 bit / 192kHz .
This product also allows playback of audio files via its USB-A input, up to 1TB.
Equipped with audiophile components such as an ESS ES9023 Sabre DAC , it will fit perfectly with your HiFi system.
iEast Récepteur audio sans-fil Multi-room WiFi DLNA UPnP AirPlay
The remote controlc allows you to select the song, manage the volume, and play or pause music when the receiver is in the file player (USB) mode. It also allows you to turn the iEast off and on, as well as select the previously configured quick access list (see operating instructions).
An iEast Play app is available on Android and iOS. It allows you to access music stored on your Smartphone, on your NAS (Synology, QNAP, etc.) ... in short, centralization of your music libraries on a single dedicated application and to easily manage the multiroom.
The iEast Audio / Streamer Receiver has been tested by Qobuz, you can read their test by following this link:
Qobuz IEAST
(Namely that Qobuz is natively supported by the iEast application, and is available in the settings on the iOS application)
You will find in the attached file below, a complete user manual of Streamer iEast.
The Streamer iEast is compatible with all these music services:
Ieast Services
Features:
  • UPNP DLNA server browser (From Ieast Application)
  • Airplay receiver (CD 16bit / 44 Khz)
  • UPNP DLNA receiver (High resolution 24bit / 192 Khz)
  • Playing audio files via USB (Files displayed into Ieast application)
Strong points :
  • Compatibility HighRes
  • Highly reliable Hifi SABRE ES9023 (with Time Domain Jitter Eliminator technologyand Hyperstream)
  • Manage a multi-room audio environment via the dedicated iEast Play application
  • Although it can be controlled via its dedicated application it does not require it to function
  • Firmware update online
  • Web Administration Interface
  • Simplified pairing to the home network with compatible boxes via WPS (Wifi Protected Setup)
  • Playing files up to 1TB on USB port
Specifications:
  • DAC SABRE ESS ES9023
  • Frequency WiFi: 2.4GHz (150Mbps max)
  • WiFi: IEE 802.11 b / g / n
  • Optical Output: Wolfson 8805
  • Sampling rate: Up to 24bit / 192kHz (DLNA / UPNP reception)
  • SPDIF: Toslink Optical Output (16bit / 44khz)
  • Dynamic range: 98dB
  • THD + N: -85dB
  • Signal Noise Ratio: 112dB
Connectors:
  • WiFi antenna included (screwable)
  • AUX input (3.5mm jack)
  • Input Micro-USB (DC 5V)
  • USB-A OTG port
  • Ethernet LAN RJ45 port
  • Optical Output: SPDIF Toslink
  • Line Out 3.5mm Stereo Jack
  • Infrared receiver for remote control
Packaging:
  • Brushed black aluminum housing
  • Housing dimensions: 85x85x25mm
  • Weight Case: 350g
  • Power adapter to Micro USB DC 5V / 1000mA
  • IR Remote Control
  • Cable Jack 3.5mm to Jack 3.5mm
  • 3.5mm Jack to RCA Stereo Cable
  • User Manual (In English)
iEast Stream Récepteur audio sans-fil Multi-room WiFi DLNA UPnP AirPlay
IEast smartphone use HD audio receiver in video:
iEAST Multi-room Wifi
- iEAST VS Bluetooth, and other technologies -
iEAST vs Bluetooth et autres technologies
InputJack 3.5mm
InputWiFi
InputRJ45
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipES9023
Max sampling rate192kHz
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Refurbished GradeGrade A
ne supporte par .OGG
Les appareils IEAST ne supportent pas le format .OGG
dommage !!
This review has been posted for [GRADE A] IEAST SOUNDSTREAM PRO M30 Media Player UPNP USB DLNA AirPlay Wifi RJ45 Multiroom ES9023
Refurbished product  - Grade A This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly...
