Refurbished product - Grade A
Product in very good condition. Very slight trace on the front of the device, not very visible.
With its Lity I, Silkline unveils an integrated amplifier capable of delivering 115W under 4Ω and 75W under 8Ω. This makes it ideal for medium to large rooms. This class A/B transistor amplifier will integrate easily into your Hi-Fi system. It is capable of driving a wide choice of passive speakers and delivers a truly transparent, soft and warm sound.
The Lity I is designed to be totally balanced, with both channels powered independently to avoid crosstalk. The channels' respective circuits are both placed towards the sides, followed by internal heat sinks to ensure heat dissipation and isolation of the channels from the toroidal transformer. The amplification components are Toshiba transistors.
The Lity I amplifier incorporates an impressive pure copper toroidal transformer and Rubycon 50V 1000µF filter capacitors to greatly limit interference. What's more, the device offers overvoltage and overcurrent protection to safeguard your system.
The RCA inputs are 24k gold-plated for fast signal transmission and corrosion resistance. In addition, they are all switched with fully sealed silver contact relays to ensure reliable signal input and low distortion. The speaker terminals are made of gold-plated pure copper for maximum conductivity and anti-oxidation protection.
Silkline has equipped its Lity I with a CS3310 volume controller featuring 0.5dB presicion. Its distortion rate is also very low, bringing the Lity I to a total harmonic distortion rate of less than or equal to 0.005% (@1W).
Silkline's Lity I features a bright VFD screen for clear information display. Its CNC-machined aluminum alloy casing is clean and simple, with a symmetrically arranged heat dissipation system for aesthetic appeal. The front panel incorporates 6 control buttons to make operation of the Lity I simple and efficient. An IR remote control also enables the amplifier to be operated remotely.
1 | Speaker terminal right channel |
2 | RCA inputs |
3 | Speaker terminal left channel |
4 | Power input - ON/OFFswitch |
Product type | Integrated amplifier |
Inputs | 4* RCA stereo |
Ouputs | Speaker terminal |
Input sensibility | 250mV |
Maximum input level | 3800mV |
Output power | 2x 115W @ 4Ω (@ THD+N 0.1%) 2x 75W @ 8Ω (@ THD+N 0.1%) 2x 130W @ 4Ω (@ THD+N 10%) 2x 90W @ 8Ω (@ THD+N 10%) |
Frequency response | 10Hz-100KHz ±1dB |
Total harmonic distorsion | ≤ 0.005% (@1W) |
SNR | > 93dB |
Channel separation | > 91dB |
Wave distorsion | < 0.001% (1KHz @ 1W) |
Phase distorsion | < 0.01° (20hz-20Khz) |
Volume control | CS3310 (0.5dB steps) |
Remote control |
Power supply | AC 220 50Hz (250V Fuse) |
Standbye power consumption | < 1W (EU CE standard) |
Dimensions (W*H*D) | 430*60*240 mm |
Color | Black |
Weight | 8kg |
Package | 1* Silkline Lity I 1* Remote control 1* Power cable |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | Dual Mono |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 115.0 |
Refurbished Grade | Grade A |
