Refurbished product - Grade B
The DAC FX AUDIO SQ5 offers 3 digital inputs including a USB, a PCM1794 DAC and a quality analog output on an AOP OPA2604 and 2 LME 49720. This DAC for an accessible budget will greatly improve any old High Fidelity channel.
Strengths:
Two small snags on the edges of the case.
DAC PCM1794 + SA9027 24bit 192kHz Black
The FX-Audio DAC-SQ5 features quality components in a compact package. Offering an electronic quality rarely encountered in this range, the SQ5 provides a warm and dynamic sound, typical of PCM1794 DAC chips. Thanks to its USB SA9027 input it can decode any high definition format coming from a Windows, Linux or Mac OS PC. Its coaxial and optical digital sockets are ideal for connecting a CD player with digital outputs or a TV with a Toslink optical output. It is also possible to change the 3 AOP on DIP8 support to adapt the sound reproduction of the device. The SQ5 is equipped with an OPA2604 and two LME49720.
" This DAC-SQ5 FX-Audio is a device to be recommended to all those who do not want to complicate their life to start listening to dematerialized music from a computer, and who moreover wish that this one is particularly pleasant to their ears, knowing that they will also be able to use this DAC with their old CD player. "
Product type | DAC |
DAC Chip | PCM1794 |
Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink |
Outputs | 1x Stereo RCA |
Supported sampling rates | USB : PCM up to 24bit 192kHz Optical / Coaxial : PCM up to 24bit 96kHz |
USB Interface | SA9027 |
THD | 0.05% |
SNR | 92dB |
Frequency response | 20Hz - 20kHz |
Supply voltage | 12V 1A |
Dimensions | 105 x 95 x 32mm |
Weight | 700g |
Color | Black |
Input | SPDIF |
Input | Optical |
Output | RCA |
DAC / ADC Chip | PCM1794 |
Max sampling rate | 192kHz |
Color | Black |
Material | Metal |
Channel | 2 (Stereo) |
Networking | No |
Remote Control | No |
Refurbished Grade | Grade B |
