[GRADE B] FX-AUDIO DAC-X6 MKII DAC Headphone Amplifier Bluetooth 5.0 aptX ES9018 QCC3008 24Bit 192kHz Black
Refurbished product - Grade B
Compact and affordable DAC / headphone amplifier offering excellent audio performance for its price range. Support Bluetooth 5.0 with apt-x protocol.
Reference : 16211
Refurbished
69,90 €tax incl.
58,25 € tax excl.
Some scratches on the case.
DAC-X6 MKII
FX-Audio X6 MKII is an ideal solution for your compact, affordable and high-performance audio systems. It works both as a DAC with volume control and headpthone amplifierand offer multiple ways to connect to various devices (USB, Coaxial, Optique & Bluetooth).
Its analog and digital circuits use high quality components to achieve great audio reproduction in its price range. More specifically it works with an excellent ESS SABRE ES9018 conversion chip. and has a Bluetooth 5.0 QCC3008 interface which supports apt-X protocol.
High quality digital / analog circuit
At the heart of the device is a digital to analog conversion chip ES9018 with Hyperstream achitecture and frequency / time correction digital filters. This technology is particularly famous for its ability to limit distortion and jitter to respect your audio files down to the smallest detail.
In this configuration the X6 MKII offers a rich and detailed sound with PCM audio files up to 192kHz - 24bit.
Its analog stage is equiped with a OP275 operating amplifier  (dual-bipolar / JFET) and a OP2134 (FET) offering a considerable headroom on its RCA output.
The headphone output uses a TPA6120 high fidelity amplifier with considerable power  (940mW @16ohm)
capable of supporting models of headphones that are usually too demanding for standard audio equipment.
Wired and non-wired connectivity
The DAC X6MKII has a USB input on a USB-B connector controlled by a CM6642 interface. The latter allows it to work directly with  audio streams from your computer. This USB connector is not used for powering the X6-MKII, which will avoid most of the typical audio noise if your PC does not have an isolated USB interface.
The device also offers two S / PDIF inputs on Coaxial and Optical connector which open many possibilities for integration with your different digital audio sources (TV, game console, CD player ... ect.)
Finally, a QCC3008 interface allows the DAC X6-MKII to directly receive the audio stream from all your devices equipped with Bluetooth connectivity. Its reception circuit is in Bluetooth 5.0 standard and supports apt-X protocols for redoubled audio precision.
A short pression on the button located on the front panel is all it takes to switch input sources. Two set of LEDs keep the user informed of the active source as well as the current sampling rate.
Its RCA Stereo output with 2Vrms level is used to connect the DAC X6 MKII with a preamplifier, a power amplifier or active speakers.
A second 6.35mm jack connector located on the front of the device allows you to easily connect your headphones.
Product typeDAC with volume control
Headphone amplifier
Max sampling rate24bit 192kHz
Output levelRCA : 2Vrms
Output power (Headphone)940mW@16Ω
900mW@32Ω
700mW@64Ω
450mW@120Ω
InputsUSB-B
Optical
Coaxial
Bluetooth
OutputsStereo RCA
Jack 6.35mm
Power SupplyDC 12V 1A (included)
Bluetooth5.0 with aptX support
THD+N (Headphone)0.006%
SNR (Headphone)112dB
Frequency response (Headphone)+0 / -0.5dB(20Hz-20kHz)
Dimensions11.7 x 17.8 x 3.6cm
Package1x DAC-X6 MKII Black
1x Power adapter 12V
1x Antenna
1x USB Cable
OutputJack 6.35mm
DAC / ADC ChipES9018
Max sampling rate192kHz
Refurbished GradeGrade B
Refurbished product - Grade B Compact and affordable DAC / headphone amplifier offering excellent audio performance for its price range....
