[GRADE B] MiniDSP BOX 2x4 Audio Processor USB 2 to 4 channels unbalanced
Refurbished product - Grade B
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog converter) & asynchronous USB Audio Class 2.0 input. Like many other miniDSP devices, 2x4 provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker. The device can also be used to manage multiple subwoofers in a home theater setup.
Reference : 16796
109,00 €tax incl.
90,83 € tax excl.
Back panel very slightly bent and bumped on the left rear corner of the frame. Perfectly functional product.
MiniDSP 2X4 HD Interface - B Revision
IIR digital filter / DAC 24bit 96Khz
In addition to its digital input, the 2x4 in miniDSP has a stereo analog input on RCA connector for connecting another Hi-Fi device with analog output. Such as a turntable via a RIAA box, or any other analog source. It is a great accessory to centralize the whole installation on a single pair of speakers, while enjoying a correction / filter that extends to the entire chain.
Interface presentation
Plug-in miniDSP 2x4 HD
Audio processor
The 2x4 features a 28 / 56bit floating-point Analog Devices audio processor. The latter allows digital audio calculations as well as control via the USB interface in real time.
The MiniDSP 2X4 provides a complete solution with USB & analog inputs, filtering and parametric EQ.
Gain
Revision of the modelB
DSP engine28 / 56bit
DAC / ADC24 bit 48kHz
Connectivity StandardAsymmetric
analog inputAsymmetric, switchable with jumper 0.9Vrms and 2Vrms
analog outputsUnbalanced: Max 0.9Vrms changed to 2V (see manual)
Digital Input / OutputMicro-USB (I2S interface)
capacitorsNichicon
Volume ControlLocation potentiometer
PilotUSB Plug & Play with real-time software setup
Dimensions75 x 75 mm
Power supplyJack DC 5.5 / 2.1
Package Contents
Interface miniDSP 2x4HDx1
12V adapter plug UK / EU / US / AUx1
shielded USB cablex1
Code to download the plug-in 2 x 4x1
Max sampling rate96kHz
Refurbished GradeGrade B
Refurbished product - Grade B The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog...
