Refurbished product - Grade S
Product in perfect condition. Cardboard packaging box very slightly damaged.
Digital Audio Player DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Black
The long-awaited new version of the Shanling M6 Walkman, the M6 Ultra, is finally here, bringing not only an upgraded Android platform, but above all marking the return of AKM DACs! Thus, the M6 Ultra is the first DAP of the brand to integrate the latest generation of AKM DACs, with four AK4493SEQ chips within a unique balanced architecture. The amplifier design has been adjusted for this Quad-DAC design, allowing for higher output power.
For the rest, the M6 Ultra adopts the design implemented by Shanling for their digital music players. It is powered by a Snapdragon 665 processor, Android 10 and the Android Global Losless Output (AGLO) technology developed by the brand for optimal performance.
First visible element, the magnificent touch screen of the M6 Ultra, a Sharp LCD panel of 5" and a resolution 1920*1080px (Full HD) and a definitio of 441ppi. This one offers a superb rendering of the colors and wide angles of vision, allowing a use as comfortable as pleasant.
The M6 Ultra is the first Shanling notebook to adopt the new generation of AKM DACs, using no less than four AK4493SEQ chips in a unique Quad-DAC design. This design is inspired by Shanling CD players, in particular, with a view to maximizing the potential of the DACs in a balanced circuit. They also support sampling rates up to PCM 32bit 768kHz, DSD512 and MQA files.
Adopting the brand new Linearin LTA8092 high voltage AOP and the now proven BUF634A buffer, combined with AKM DACs, the Shanling M6 Ultra offers a slightly warmer and smoother reproduction, carrying on the signature sound that has made the brand successful.
The DAC section of the M6 Ultra also embeds four TI OPA1612 AOs, separating the balanced audio signal between the four DACs. This architecture allows for a completely independent balanced output.
The low-pass filter of the M6 Ultra uses two TI OPA2211 PDOs, chosen for their low noise and high bandwidth.
Two Japanese KDS active oscillators and Shanling's improved algorithm enable better accuracy, with greatly reduced jitter and improved performance for digital signal transmission.
The newly designed amplifier of the M6 Ultra allows it to reach a much higher power than the previous models. It is therefore capable of accompanying a greater number of headphones, including models with a high impedance and therefore more demanding.
Whether you have headphones or earphones with a 3.5mm or 4.4mm jack, the M6 Ultra will adapt. Indeed, it provides two outputs: the first, balanced, is in 4.4mm jack format and the second, single-ended, in 3.5mm jack format.
With the M6 Ultra, autonomy is no longer a problem. Its large 5650mAh battery provides 13.5 hours of single-ended playback, 9 hours of balanced playback and 58.5 hours of Bluetooth transmission. Moreover, it integrates the fast charge technology QC3.0 18W.
Easily connect your M6 Ultra to any Bluetooth wireless headphones or speakers and enjoy exceptional sound quality with support for the high-resolution wireless transmission codecs aptX, aptX HD and LDAC. The M6 Ultra can also function as a receiver and thus be connected via Bluetooth to a source.
En plus de sa connectivité Bluetooth, le M6 Ultra est équipé d'un module réseau WCN3980, supportant le WiFi 2.4G/5G et la technologie MIMO, assurant une connexion rapide et stable. Une connexion qui vous permettra d'accéder à la musique stockée sur votre réseau, sur un ordinateur ou un NAS par exemple, en utilisant les protocoles DLNA ou AirPlay. Par ailleurs, cette fonction vous permettra également de profiter de vos services de streaming et webradios préférés.
Inside the M6 Ultra is a powerful eight-core Snapdragon 665 processor associated with 4GB of LPDDR4X RAM, offering very good computing performance for a smooth and pleasant use of the DAP. It also has 64GB of internal storage, which can be expanded by using a Micro SD card (not included).
The Android 10 platform gives you access to a variety of applications to suit your needs. And with AGLO, the onboard technology for Android Global Lossless Output, your music is processed in its highest quality, without degradation caused by Android's sample rate converter.
Working as a total decoder, the M6 Ultra is capable of playing high-quality 16x MQA streams via the Tidal streaming app. Master Quality Authenticated (MQA) technology allows you to enjoy sound reproduction as close as possible to the original studio recording.
Product type | Digital audio player (DAP) |
Touchscreen | 5" 1080*1920px |
OS | Open Android 10 |
Inputs | Bluetooth 5.0 Internal storage 1x Micro SD slot |
Outputs | Bluetooth 5.0 1x Jack 4.4mm balanced headphone output 1x Jack 3.5mm single-ended headphone output |
WiFi Connectivity | WiFi 2.4G/5G MIMO |
Supported audio formats | DSD (.iso, .dsf, .dff), DST ISO, ISO, DXD, APE, FLAC, WAV, AIFF, ALF, DTS, MP3, WMA, AAC, OGG, MQA, ALAC, MP2, M4A, AC3, M3U, M3U8 |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
Gain setting | 3 levels |
RAM | 4Go |
Internal storage | 64Go |
DAC | 4x AKM AK4493SEQ |
Digital filters | 7 preset filters |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | Transmission : SBC, aptX, aptX HD, LDAC Reception : SBC, LDAC |
Single-ended output Performances | |
Output power | Low gain : 16mW @ 32Ω Medium gain : 92mW @ 32Ω High gain : 240mW @ 32Ω |
Frequency response | 20Hz - 40kHz (-0.2dB) |
THD+N | 0.0005% |
Channel separation | 75dB @ 32Ω |
Dynamic range | 122dB |
SNR | 122dB |
Noise | > 116dB (< 1.6µV) (low gain) |
Output impedance | < 1Ω |
Balanced output Performances | |
Output power | Low gain : 61mW @ 32Ω Medium gain : 360mW @ 32Ω High gain : 720 mW @ 32Ω |
THD+N | 0.0005% |
Channel separation | 115dB @ 32Ω |
Dynamic range | 125dB |
SNR | 125dB |
Noise | > 114dB (< 2.1µV) |
Dimensions | 127 x 77 x 18mm |
Weight | 263g |
Color | Black |
Package | 1x Shanling M6 Ultra 1x USB-C to USB-A cable 2x Protection screen |
Input | Micro SD |
Input | Bluetooth |
Input | WiFi |
Output | Jack 4.4mm |
Output | WiFi |
Output | Jack 3.5mm |
Output | Bluetooth |
DAC / ADC Chip | AK4493SEQ |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Black |
Refurbished Grade | Grade S |
