Refurbished product - Grade S
xDuoo offers with its X2S a particularly compact and practical digital music player, offering however very good sound performances. Its internal architecture allows it to support high resolution audio streams, up to PCM 24bit 192kHz and DSD128, the decoding being done efficiently by the integrated CPU.By buying this product you get 5 loyalty points
Product in perfect condition.
Digital Audio Player DAP 24bit 192kHz DSD128
xDuoo offers with its X2S a particularly compact and practical digital music player, offering however very good sound performances. Its internal architecture allows it to support high resolution audio streams, up to PCM 24bit 192kHz and DSD128, the decoding being done efficiently by the integrated CPU. The DAP has a nice OLED display on the front panel, allowing to display in real time the information related to the current playback but also to access the different parameters of the device.
To allow you to store your entire music library, the X2S can accept a Micro SD card, with a capacity of up to 128GB (not included).
The X2S amplifier circuitry uses a rail-to-rail AOP, allowing it to develop a nice power reserve to accompany many models of headphones and earphones on the market.
Versatile, the X2S adapts to all types of listening, notably thanks to the presence of predefined filters but also a 6-band equalizer, adjustable over a gain range from -6dB to +6dB. It is thus possible to adapt the sound reproduction of the device according to your listening device, your music or your tastes.
The X2S has a beautiful 0.96" OLED screen on the front. This one allows to display in real time the information concerning the audio stream in progress as well as the parameters of the device. This one also allows to navigate in an intuitive way through the menus of the device.
Product type | Digital Audio Player (DAP) |
Power output | 250mW @ 32Ω |
Frequency response | 20Hz - 20kHz (±0.5dB) |
Gain | +6dB |
THD+N | 0.003% (1Khz) |
SNR | 108dB |
Acceptable headphone impedance | 16~300Ω |
Battery | 800mAh 3.7V |
Autonomy | > 10h |
Charging time | < 2h |
Supported file formats | DSD : DSD64-DSD128 (DFF, DSF) APE : 16-24it/44.1-96kHz FLAC : 16-24it/44.1-192kHz WAV : 16-24it/44.1-192kHz AIFF : 16-24it/44.1-192kHz WMA, MP3, AAC, OGG |
Charge voltage | 5V 1A |
Micro SD support | Up to 128Go (not included) |
Dimensions | 6.3 x 4 x 1.5cm |
Weight | 50g |
Color | Gray |
Input | Micro SD |
Output | Jack 3.5mm |
DAC / ADC Chip | NC |
Max sampling rate | DSD128 |
Max sampling rate | 192kHz |
Color | Gray |
Refurbished Grade | Grade S |
