[GRADE S] XDUOO XD05 BAL Portable Balanced Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver
Refurbished product - Grade S
The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its digital/analog conversion stage has been updated, its Bluetooth wireless connectivity is now directly integrated and it now benefits from a balanced output.
By buying this product you get 39 loyalty points
Reference : 17980
Refurbished
399,00 €tax incl.
332,50 € tax excl.
Product in perfect condition. Cardboard box (packaging) very slightly damaged.
xDuoo XD05 BAL
xDuoo XD05 BAL Amplificateur Casque Portable Symétrique 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Argent
Comfortable power output
With a power reserve of 1000mW under 32Ω, the XD-05 Plus has a comfortable power output that allows it to accompany many headphone models without difficulty.
Dual ESS9038Q2M DAC & XMOS XU208 Interface
A major change for this BAL version of the XD05 is that the XD05 now carries two ESS ES9038Q2M DAC chips, each one handling one channel. These provide high quality, pure and accurate sound reproduction, while supporting high-resolution audio streams up to 32bit 768kHz PCM and DSD256.
This conversion stage is notably associated with a fast and reliable XMOS XU208 USB interface.
A particularly complete connection system
The XD05 BAL benefits from full and versatile connectivity. It features digital inputs from USB-C, AES/EBU and Optical / Coaxial shared on a 3.5mm jack connector. For its outputs, the XD05 BAL offers an unbalanced 6.35mm jack and a balanced 4.4mm jack. Finally, a 3.5mm jack connector can be used as an auxiliary input or output.
iFi Audio iPower Elite Adaptateur Secteur à Annulation de Bruit Active 5V 5AxDuoo XD05 BAL Amplificateur Casque Portable Symétrique 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Argent
Wireless Connectivity
New in this version of the XD05, the XD05 now has an internal Qualcomm CSR8675 Bluetooth 5.0 receiver chip. The latter also supports the high-resolution aptX HD and LDAC transmission protocols.
Internal battery or external power supply, it's your choice
Like its predecessor, the XD05 BAL integrates a 3.8V battery of 5000mAh. However, there is now a simple switch to choose between using the device on battery power or via an external power supply. Convenient for use in Amplifier / DAC sedentary mode.
OPA Double interchangeable
The XD-05 BAL integrates a double AOP mounted on a DIP8 support. It is therefore extremely easy to replace it with another model, without the need for soldering, in order to enjoy a different sound.
Caution! Be careful when changing these components, as any improper handling that damages the device or OPA will void the warranty.
Product typeBalanced portable headphone amplifier / DAC
Inputs1x USB-C
1x Coaxial / Optical onJack 3.5mm
1x AES/EBU
1x AUX Jack 3.5mm
Outputs1x Single-ended Jack 6.35mm
1x Balanced Jack 4.4mm
1x AUX Jack 3.5mm
DAC Chips2x ESS ES9038Q2M
USB InterfacesXMOS XU208
Bluetooth chipQualcomm CSR8675
Bluetooth version5.0
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Battery3.8V 5000mAh
Gain setting+6dB
-15dB
Frequency responseUSB / SPDIF : 20Hz - 20kHz
AMP : 10Hz - 60kHz
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
AES/Optical/Coaxial : PCM up to 24bit 192kHz, DSD up to DSD64
Output power1000mW @ 32Ω
THD+N0.0015% @ 1kHz, Jack 6.35mm
0.0008% @ 1kHz, Jack 4.4mm
SNR115dB @ Jack 6.35mm
117dB @ Jack 4.4mm
Crosstalk≥72dB @ Jack 6.35mm
≥100dB @ Jack 4.4mm
Output level (AUX)2Vrms
Dimensions130 x 75 x 22mm
Weight290g
InputAES/EBU
InputJack 3.5mm
InputOptical Mini-Toslink
OutputJack 6.35mm
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorGray
ClassN/A
Refurbished GradeGrade S
Xduoo XD 05 Bal
Excellent appareil qui a transformé mon écoute casque sur un Sivga P2.
Tout est en place: précis, transparent, dynamique et timbré.
Les grosses masses orchestrales symphoniques passent comme une lettre à la poste!
L'écoute à partir du Yamaha WXC 50 utilisé comme streamer+dac vers l'ampli Audiophonics K 214 (malgré ses grandes qualités d'amplification Class A) m'avait laissé sur ma faim..
On ne peut pas réellement utiliser ce Xduoo en mode nomade (malgré sa batterie interne), vu son encombrement et son poids..
This review has been posted for [GRADE S] XDUOO XD05 BAL Portable Balanced Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver
Refurbished product  - Grade S The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its...
