Refurbished product - Grade B
Small tear on the top front edge of the case.
Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DS256
Versatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best possible way. Combining comfortable power, a powerful DAC, complete connectivity and precise volume control, this amplifier is a must-have for anyone who wants to equip themselves with a quality sound system without having to worry about a multitude of devices dedicated to specific functions. The DAW-S250NC also opens the doors to music streaming thanks to its WiFi LinkPlay connectivity, allowing you to access your music from your network and your favorite applications.
The real engine of this DAW-S250NC, the Hypex NCore NC252MP Class D amplifier module delivers considerable power, up to 2x250W under 4Ω, with great efficiency and ease, while maintaining a compact size. Its main characteristic reveals itself in its great linearity and its ability to ensure a very low level of distortion. The DAW-S250NC reveals a sound reproduction as transparent as detailed to present you your music as close as possible to its recording in studio.
The NCore NC252MP also features its own SMPS power supply, consisting of a regulated half-bridge converter with synchronous rectification on the main output rails. This design is ideally suited for integration with a Class D amplifier, providing the amplifier with a stable, clean electrical signal and capable of responding quickly to more sudden power requirements.
The DAW-S250NC's digital-to-analog conversion is handled by a widely proven and audiophile-approved DAC, the ES9038Q2M from ESS Technology. This chip uses the patented HyperStream® II 32bit architecture and Time Domain Jitter Eliminator technology to deliver excellent performance. The result is incredibly accurate sound reproduction that captures every detail of your music.
This DAC also opens the door to very high resolution, supporting PCM audio streams up to 32bit 768kHz and DSD up to DSD256.
The DAW-S250NC offers a complete range of connections to easily integrate into your audio system and adapt to your use. Its rear panel features digital inputs, coaxial, optical Toslink and USB-B (XMOS). For the outputs, you can of course count on high quality speaker terminals, but also on a Pre-Out output via RCA.
This RCA output offers you several possibilities:
- connect an active subwoofer
- connect another integrated amplifier
Take control of your DAW-S250NC remotely in a perfectly intuitive way with its WiFi connectivity. Featuring a WiFi module based on proven LinkPlay technology, the DAW-S250NC lets you stream your music over your network, whether from your smartphone, computer, NAS, or any other connected device. The module is compatible with DLNA/UPnP, AirPlay and Spotify Connect protocols.
Also enjoy access to your favorite streaming applications and web radios through a dedicated control application, allowing you to remotely control your device through an ergonomic interface.
In addition, it also becomes possible to integrate multiple DAW-S250NC amplifiers into a multi-room system, all of which can be controlled synchronously or independently via the app. This means you can equip different rooms in your home while keeping control of the system in a completely transparent way.
Moreover, the WiFi module is bit-perfect, allowing playback as close as possible to the original signal, even for high-resolution audio streams up to 24bit 192kHz.
The WiiM Home application, available for free on Android and iOS, allows you to remotely control your DAW-S250NC via WiFi. Thanks to its ergonomic and intuitive interface, simply stream your music from your smartphone and connect to your home network. You'll also have access to numerous audio streaming platforms, such as Spotify, Deezer, Tidal, Qobuz, Amazon Music and even TuneIn and iHeartRadio web radios.
Want to set up a multi-room system to enjoy your music throughout your home? WiiM Home also allows you to control each device connected to it, either synchronously or independently, all in a single application.
In addition to its physical connectivity, the DAW-S250NC provides high quality Bluetooth 5.0 reception capability, which is extremely convenient and will allow you to stream and control your music wirelessly quickly and easily, directly from your smartphone or tablet for example.
The components are perfectly protected by a robust aluminum case. Optimal heat dissipation is provided by a series of openings on the cover and rear panel, allowing for good airflow. The front panel of the DAW-S250NC features a beautiful black acrylic front panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED screen, which displays the volume level, the active input or the type of signal received by the device. It will also allow you to navigate through the menus and access all the options of the DAW-250NC.
Product type | Integrated amplifier |
Inputs | Bluetooth 5.0 WiFi 1x USB-B 1x Coaxial 1x Optical Toslink |
Outputs | Speaker terminals 1x Stereo RCA Pre-Out |
Amplifier | Hypex NCore NC252MP |
DAC | ESS ES9038Q2M |
USB Interface | XMOS XU208 |
Output power | 2x 250W @ 4Ω 2x 150W @ 8Ω |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD DoP up to DSD256 Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
THD+N | 0.0015% |
SNR | 121dB |
OLED Screen | Brightness not adjustable, but switches off after 40 seconds |
Supported WiFi protocols | DLNA / UPnP AirPlay Spotify Connect |
Supported streaming services (via WiiM Home app) | Spotify Deezer Tidal Qobuz Amazon Music Napster Pandora QQMusic |
Supported webradios (via WiiM Home app) | TuneIn iHeartRadio RadioParadise vTuner |
Power supply | 110-230V AC |
Color | Gray |
Dimensions | 300*295*60mm |
Weight | ~ 2.45kg |
Package | 1x Audiophonics DAW-S250NC 1x Remote control (batteries included) 1x Power cable 1x Bluetooth / WiFi antenna |
FFT measure - 5W - 4 Ohm
FFT measure - 4.4V Rms No load
Input | Optical |
Input | WiFi |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Output | Speaker terminal |
Output | RCA |
Color | Gray |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Hypex Ncore |
Power (W) | 250.0 |
Remote Control | Yes |
Refurbished Grade | Grade B |
