Refurbished product - Grade B
A few dents and tears. Two fins slightly bent. Works perfectly.
This regulated linear power supply 12V 5A with two jack outputs : 5.5/2.1 and 5.5/2.5, is dedicated for HiFi audio devices requiring a clean and neat power supply. It will reduce background noise, a lowering of the "ripple" harmful to the jitter on digital audio devices such as DAC or high fidelity streamers. The result is an improvement of the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and a better dynamic bass.
Thes components of this power supply are of first quality:
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two Jack DC 5.5 / 2.1 & 5.5 / 2.5, this power supply with an extremely stable 100VA transformer even under heavy load, and will allow you to make the best of the connected audio components requesting from 12V up to 5A (7.5A at peak) .
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Input | IEC C14 |
Output | Jack DC 5.5/2.1mm |
Output | Jack DC 5.5/2.5mm |
Color | Black |
Output voltage (V) | 12.0 |
Output current (A) | 5.0 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
Refurbished Grade | Grade B |
