Aune X1S Pro DAC
Refurbished product - Grade S
The X1s Pro is the 7th generation of the Aune X1 range. With its DAC ES9038Q2M with 3 filters and decoding capabilities up to PCM 32bit 768kHz and DSD512, the device looks like a high-performance DAC and headphone amplifier!
By buying this product you get 22 loyalty points
Reference : 18538
Refurbished
229,00 €tax incl.
190,84 € tax excl.
Product in perfect condition.
Aune X1S Pro
DAC ES9038Q2M Headphone Amplifier 32bit 768kHz DSD512Aune X1s Pro DAC ES9038Q2M Amplificateur Casque 32bit 768kHz DSD512
The RCA input is only connected to the headphone output. It is not pavailable on the RCA output.
The X1s Pro is the 7th generation of the Aune X1 range. With its DAC ES9038Q2M with 3 filters and decoding capabilities up to PCM 32bit 768kHz and DSD512, the device looks like a high-performance DAC and headphone amplifier! The X1s Pro can be connected to a USB computer to function as an external DAC to significantly improve the sound quality of your machine. The X1s Pro can also be combined with a pair of active speakers or headphones to allow your system to reach its full potential.
In addition to this USB-B input, the X1s also offers Coaxial S/PDIF, Toslink Optics and a line input in stereo RCA format. These allow the X1s to be connected directly to another HiFi device such as a file player to enjoy your music without the need for a computer. On the output side, the X1S offers RCA on its rear panel and a 6.35mm jack on the front panel to connect a headset.
The amplification stage of the Aune X1S is based on a Class AB circuit. The latter is able to deliver with immense precision and sound richness, a power of 550mW under 32Ω, allowing it to be associated with many headphones on the market. 3 filters allow you to adapt the playback according to your listening and audio system: Fast roll-off, Slow roll-off, Apodizing fast filter.
For its power supply, the device features an architecture that separates digital and analog circuits with a powerful voltage regulation system to improve dynamics and sound image. This careful design allows the Aune X1S to perform excellent measurements with an ultra-low noise of 3.5µV, a THD+N that is also well placed at -102dB and a dynamic range of 117dB. These measures are the assurance of a certain quality of restitution.
Aune X1s Pro DAC ES9038Q2M Amplificateur Casque 32bit 768kHz DSD512Aune X1s Pro DAC ES9038Q2M Amplificateur Casque 32bit 768kHz DSD512
SpEcifications
Product typeDAC and Headphone Amplifier
DAC chipES9038Q2M
Inputs1x USB-B
1x Coaxial S/PDIF
1x Optical Toslink
Outputs1x RCA Stereo
1x Jack 6.35mm
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial : PCM up to 24bit 384kHz, DoP up to DoP128
Optical : PCM up to 24bit 192kHz, DoP64
RCA output level2Vrms
RCA output frequency response20Hz - 20kHz (+/-0.2dB)
SNR117dB
THD+N @ 1kHz-102dB
Output power560mW @ 32Ω (0.1% @ 1kHz 0dB)
Package1x Aune X1s Pro
1x Power supply 9V 2A
1x Male Jack 6.35mm to female Jack 3.5mm adapter
1x USB cable
1x CD with drivers and user manual
THD+N (10Hz - 20kHz)
Frequency response (20Hz - 20kHz)
Dynamic range
OutputJack 6.35mm
Refurbished GradeGrade S
[GRADE S] AUNE X1S PRO DAC ES9038Q2M Headphone Amplifier 32bit 768kHz DSD512 Black
Refurbished product - Grade S The X1s Pro is the 7th generation of the Aune X1 range. With its DAC ES9038Q2M with 3 filters and decoding...
