[GRADE S] GUSTARD C18 OCXO Clock Silver
-6%
Refurbished product - Grade S
This high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio signals to improve the sound quality of a HiFi system. The C18 is equipped with an ultra-low noise oscillator.
Reduced price!
Reference : 20646
Refurbished
Limited special offer
1 599,00 €tax incl.
-6%
1 499,00 €tax incl.
1 249,17 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
Brand new product, old version (no impedance selector on rear).
Gustard C18
Master Clock OCXO 10MHz Silver
Gustard C18 Horloge Maître OCXO 10MHz Argent
OCXO 10MHz
The oscillator used here is a 10MHz OCXO, designed to promote a constant temperature and thus minimize changes in output frequency caused by temperature variation. Specially designed for audio, it allows you to achieve a greater level of detail, a more realistic sound signature and a higher dynamic range.
Independent output stage
The output circuit of the C18 maintains and does not deteriorate the low phase noise signal provided by the main oscillator. The GDRV-P1 can also provide both a sine and a square wave signal to accommodate different devices.
Discrete power supply
The C18 features a discrete Class A power supply circuit that is highly efficient, providing low ripple and fast response.
Product typeMaster clock
Output frequency10MHz
Frequency accuracy< ±300ppb
Frequency stability< ±50ppb
Output amplitude7dBm @ 50Rz
Output waveformSinus
Square
Output impedance50Ω
Bruit @ 1Hz (TYP)-110dBc
Voltage supply115-230V AC 50/60Hz
Consumption< 15W
Dimensions220 x 170 x 50mm
Weight~ 2.5kg
ColorSilver
Refurbished Grade
  • Grade S
[GRADE S] GUSTARD C18 Master Clock OCXO 10MHz Silver
Refurbished product - Grade S This high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio...
