Refurbished product - Grade S
Brand new product.
HDMI to HDMI / Optical / Jack 3.5mm 5.1 18Gbps HDCP 2.2 4K 60Hz HDR 3D
This extractor allows you to recover and extract an HDMI signal at input, and then output it as HDMI, Toslink optical and 3.5mm jack, so you can distribute the audio signal independently. The extractor is compatible with 4K, HDR and 3D technologies, with a bandwidth of 18Gbps. A selector allows you to choose the number of channels, for stereo, 5.1 or pass-through operation. Similarly, a switch enables you to activate or deactivate the ARC function.
When using HDMI and optical outputs simultaneously, be sure to use cables with compact connectors. The extractor's HDMI and optical outputs are close to each other.
1 | Pass-through / 2.0 / 5.1 audio format switch |
2 | HDMI input |
3 | Power LED indicator |
4 | Power connector |
5 | HDMI output |
6 | Output signal LED indicator |
7 | Toslink optical output |
8 | Audio output 3.5mm jack |
Product type | HDMI extractor |
Input | 1x HDMI |
Outputs | 1x HDMI 1x Optical Toslink 1x Jack 3.5mm |
Supported resolutions | 4K 60Hz, 2K, 1080p, 720p... |
Supported technologies | HDR 3D |
Max bandwidth | 18Gbps |
Package | 1x HDMI extractor 1x USB-A to Jack DC cable |
Input | HDMI |
Output | Jack 3.5mm |
Output | Optical Toslink |
Output | HDMI |
Color | Black |
Refurbished Grade | Grade S |
