[GRADE B] IFI AUDIO ZEN STREAM Hi-Res Audio Streamer WiFi DLNA 32bit 384kHz DSD256 MQA
-10%
Refurbished product - Grade B
Behind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you to stream your music from the Internet to your DAC, without any loss of quality. Hi-Res certified and capable of playing streams up to PCM 32bit 384kHz and DSD256 via WiFi / LAN, you just need to associate a connected device to the Zen Stream to simply enjoy your music.
Reduced price!
Reference : 19201
Refurbished
Limited special offer
399,00 €tax incl.
-10%
359,00 €tax incl.
299,17 € tax excl.
Last items in stock !
Shipping date: 25-04-2025.
Product reconditioned by manufacturer. Damaged cardboard packaging. Ethernet RJ45 cable missing.
iFi Audio Zen Stream
iFi Audio Zen Stream Lecteur Réseau Audio Hi-Res WiFi DLNA 32bit 384kHz DSD256 MQA
Behind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you to stream your music from the Internet to your DAC, without any loss of quality. Hi-Res certified and capable of playing streams up to PCM 32bit 384kHz and DSD256 via WiFi / LAN, you just need to associate a connected device to the Zen Stream to simply enjoy your music. Its optimized open source architecture offers a particularly wide compatibility and regular updates.
The Zen Stream's architecture incorporates high-quality components in an optimized circuit. These include two SuperSpeed USB 3.0 ports with Active Noise Cancellation II technology, a Coaxial SPDIF output with integrated iPurifier, a power supply using Silent Power technology and a software layer based on Volumio and enhanced and optimized by iFi Audio engineers.
Optimized in every detail
Zen Stream benefits from a particularly well optimized software layer. From the drivers to the kernel and shell, from the applications to the user interface, everything is optimized for smooth and transparent operation and excellent sound performance.
The streamer also offers the possibility to select "exclusive" modes, i.e. individual settings dedicated to specific operating modes in order to offer the purest possible performance. All other programs are disabled in order to minimize software jitter, an often neglected aspect that has a negative impact on the sound quality.
Operating modes
  • All-in-one (AIO) mode : covers all modes
  • DLNA Streaming
  • NAA Streaming
  • Roon Bridge Streaming  (Roon Ready)
  • Tidal Streaming
Versatility at its best
The Zen Stream offers extensive connectivity for maximum versatility:
  • Play directly from Spotify/Tidal using Spotify Connect and Tidal Connect protocols.
  • Works with DLNA certified applications.
  • AirPlay integrated (Chromecast to come in a future update).
  • Compatible with Roon.
  • NAA operation with the Sygnalist HQPlayer software.
Qobuz is only available on iOS via Airplay or on Android via Bubble UpNP.
An exceptional design
Particularly powerful, the Zen Stream is equipped with high-end components and advanced technologies.
  • Quad Core ARM Cortex 64bit processor.
  • USB and SPDIF interfaces regulated by a femtosecond GMT clock to eliminate jitter.
  • Active Noise Cancellation II and iPurifier technologies for USB and SPDIF interfaces
  • Intelligent Ethernet controller with low idle current and low voltage dropout.
  • High precision 1.6MHz synchronous power controller.
  • C0G capacitors, Taiyo Yuden and Murata low ESR coils.
Product typeStreamer
InputsWiFi
Ethernet RJ45
1x USB-A 3.0 (USB Host)
Outputs1x Coaxial SPDIF
1x USB-A 3.0
DSD up to DSD256
MQA
Supply voltage9VDC 1.8A - 15VDC 0.8A
ConsumptionNo signal : ≈6W
Max signal : ≈10W
Dimensions158 x 100 x 35mm
Weight578g
ColorBlack and silver
IFI AUDIO ZEN STREAM Lecteur Réseau Audio Hi-Res WiFi DLNA 32bit 384kHz DSD256 MQA
InputWiFi
InputRJ45
OutputCoaxial SPDIF
OutputUSB
DAC / ADC ChipNC
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsTidal
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsDLNA
Refurbished GradeGrade B
Refurbished product - Grade B Behind its modern design, the iFi Audio hides an extremely powerful network player. Its sole purpose: to allow you...
