Refurbished product - Grade S
Product in perfect condition.
With its ALBA in-ear monitors, MEZE presents dynamic IEMs with Ø10.8mm drivers. They feature an extended frequency response of 15Hz-25kHz for a wide soundstage. Their 32-ohm impedance and sound pressure level of 109dB/1mW (32 ohm) make them easy to drive and offer a high level of compatibility, whether for use with a DAP or a headphone amplifier, for example. The ALBAs promise clear, precise sound reproduction thanks to a distortion level of <0.1% (1kHz). A 2x CIEM 0.78mm to 3.5mm jack cable with silver-plated conductors and a 3.5mm to USB-C adapter with integrated DAC/Amp chip complete the package. This adapter supports PCM 32bit 384kHz high-definition streams, enabling you to enjoy audiophile listening with a source such as your smartphone.
Made from zinc-aluminum alloy, these earphones are very durable, but also lightweight, for a pleasant level of comfort during long listening sessions. Their modern look and white pearl color also make them visually pleasing.
The detachable 2x CIEM 0.78mm to 3.5mm gold-plated cable features silver-plated conductors for high conductivity, as well as corrosion and oxidation resistance for its termination. In addition, a jack 3.5mm female to USB-C male adapter with integrated DAC/Amp chip enables the Meze Alba to receive high-resolution streams up to PCM 32bit 384kHz if you wish to use them with a USB-C smartphone.
The reputation of Meze headphones is well established, but purchasing one requires a certain budget. With the Alba dynamic IEMs, the brand makes its rather neutral, warm sound signature accessible to the widest possible audience. The Alba headphones are a good entry-level product for anyone wishing to benefit from the quality of MEZE products.
Product type | In-ear Monitors |
Drivers | Dynamics |
Speakers diameter | 10.8mm |
Impedance | 32 ohms |
Sound pressure level (SPL) | 109dB/1mW, 32 ohm |
THD+N | < 0.1% @ 1kHz |
Cable | Detachable cable 2x CIEM 0.78mm to 3.5mm jack termination |
Cable conductor plating | Silver |
Cable length | 1.20m |
3.5mm jack termination plating | Gold |
3.5mm jack to USB-C adapter | Integrated DAC/Amp chip |
Weight | 14g |
Color | White |
Package | 1x MEZE Alba dynamic IEM 1x Detachable cable 2x 0.76mm CIEM to 3.5mm jack termination 1x 3.5mm jack to USB-C adapter with integrated DAC/Amp 4x Pair of ear tips (S, M, L, XL) 1x Storage pouch |
Color | White |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 109 |
Lowest frequency (Hz) | 15 |
Highest frequency (Hz) | 25000 |
Refurbished Grade | Grade S |
