Refurbished product - Grade S
Version (21).
CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Black
The Shanling CD-S100 (21) is a high quality, high performance and versatile CD player. The core of the system is based on a dual-core Junzheng X2000 processor using XBurst2 architecture, ensuring high power for data processing. The digital-to-analog conversion stage uses an AKM AK4493 chip, efficiently decoding the audio stream for accurate sound reproduction. The CD playback is done by a Philips CD80 servo system and a Sanyo HD850 playback head.
The CD-S100 (21) is also equipped with a Bluetooth 5.0 reception function thanks to the integration of an AP6256AC chip. This one thus allows a wireless audio transmission, from a smartphone for example, and is compatible with the LDAC high quality Bluetooth codec.
There is also an input USB-A port for reading files from a storage device, or a USB-B input, capable of reading high resolution streams up to PCM 32bit 768kHz and DSD512.
For its outputs, the CD-S100 (21) provides an analog output on stereo RCA, as well as two digital outputs, in optical and coaxial formats.
Finally, the front panel of the device features a nice round LCD display with a resolution of 320*290px, capable of displaying information about the current playback as well as the album covers.
If the Shanling CD-S100 (21) can be controlled in the traditional way thanks to the remote control supplied with the device, it can also be controlled using the free mobile application Edict Player. This application allows you to browse your music library and also to directly control the playback of your music.
Product type | CD Player |
Inputs | CD Bluetooth 5.0 1x USB-B 1x USB-A Host |
Outputs | 1x Stereo RCA 1x Optical Toslink 1x Coaxial |
CPU | Junzheng X2000 |
DAC Chip | AKM AK4493 |
OPA | OPA2134 |
USB Interface | Junzheng X2000 |
Screen | AMLCD 320*290px |
Control mode | Remote control App |
Supported sampling rates | PCM up to 32bit 768kHz DSD512 |
Supported file formats | DSD, DXD, APE, FLAC, ALAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, MP3, M4A, AC30PUS, TAK, CUE |
Output level | 2V |
Frequency response | 20Hz-20kHZ ±1dB |
SNR | 110dB |
Distortion | < 0.001% |
DNR | 100dB |
Dimensions | 430 x 355 x 79mm |
Weight | ≈ 5.3kg |
Color | Black |
Package | 1x CD-S100 (21) Black 1x Power cable 1x Remote control |
