[GRADE B] SILKLINE ZUKI I Balanced preamplifier / DAC 32bit / 192kHz USB XMOS
-21%
Refurbished product - Grade B
Silkline's Zuki I combines the functions of preamplifier and DAC. The preamplifier function has a balanced and unbalanced output and a voltage gain of 12dB. High-performance ADI AD1955 conversion chip decodes up to 32-bit / 192Khz PCM.
Reduced price!
Reference : 19289
Refurbished
Limited special offer
389,00 €tax incl.
-21%
309,00 €tax incl.
257,50 € tax excl.
Scratch on unit top panel.
SILKLINE ZUKI I
Balanced Preamplifier / DAC AD1955 32bit / 192kHz USB XMOS
SILKLINE ZUKI I Préamplificateur symétrique / DAC AD1955 32bit / 192kHz USB XMOS
Silkline Zuki I combines the functions of preamplifier and DAC. The preamplifier function has a balanced and unbalanced output and a voltage gain of 12dB. High-performance ADI AD1955 conversion chip decodes up to 32-bit / 192Khz PCM. Moreover, it is equipped with an XMOS XU208 USB interface, an 8-core processor working with FGPA, and a CS8416 SPDIF receiver. On the input side, the Zuki I offers a full range of connectors, while outputs include RCA and balanced XLR.
Overall, the Zuki I delivers excellent performance and transparent sound. Its simple, elegant appearance makes it easy to integrate into any Hi-Fi audio system.
Quality components
Silkline chose to integrate top-quality, market-renowned components to position the Zuki I as a high-resolution audio preamplifier / DAC.
Balanced preamplifier with source selection
With a gain of 12dB, this SilkLine preamplifier lets you balance an analog input signal on an RCA input, thanks to its balanced XLR output. On the front panel, 6 buttons allow you to select the input source, whether digital (USB-B / AES/EBU / Toslink / Coaxial) or analogue (4x RCA). The Zuki I also features an IR remote control for distant audio control.
A high-performance volume controller and OPA
Silkline has equipped the Zuki I with a CS3310 volume controller featuring a precision level of 0.5dB and an ultra-low distortion level of 0.001%.
Two Burr Brown OPA 2134PA amplify the signal. They combine the precision and low noise of bipolar transistors with the speed and sound quality of JFETs. This results in very good THD, low noise and low power consumption. Integrated in DIP8 format, they are easily replaceable.
The Zuki I is equipped with a USB-B input and a second-generation USB XMOS interface that supports 32bit/192Khz PCM and is USB Hi-RES Audio 2.0 certified. This 8-core USB interface provides fast signal processing of up to 1000Mps.
In addition, the USB interface supports the Foobar ASIO driver, making it compatible with a wide range of devices.
Please note: the Silkline USB interface requires a driver to be installed on your source device. (SilkLine or Foobar ASIO driver)
An oversampling, SA-CD-compatible D/A conversion chip
SilkLine chose to integrate a high-performance, stereo ADI AD1955 DAC chip. This DAC chip features an up to eight times oversampling function, considerably reducing the noise generated by D/A conversion. It also supports the SA-CD (Super Audio CD) format, a high-end CD format whose standard is DSD64.
A professional SPDIF receiver
The ZUKI I features a CS8416 SPDIF audio receiver. This receiver automatically adapts to different sampling rates and supports up to 24bit / 192Khz. This receiver features extremely low jitter of less than 200ps and is connected to three different types of input: an AES/EBU input, two Toslink optical inputs and two coaxial inputs.
A complete range of connectors
1USB-B input
2AES/EBU input
32x Toslink optical input
42x SPDIF Coaxiale input
54x RCA analog input
6Stereo RCA output
7Balanced XLR output
8IEC power supply / Power switch ON/OFF
Product typeBalanced preamplifier
DAC
Inputs1x USB-B
1x AES/EBU
2x Optical Toslink
2x Coaxial
4x RCA
Outputs1x RCA
1x Balanced XLR
DAC chipADI AD1955
USB interfaceXMOS XU208
OPAOPA 2134PA
Supported sample ratesUSB : 32bit / 192Khz
Coaxial : 24bit / 192kHz
Optique : 24bit / 192kHz
AES/EBU : 24bit / 192kHz
Frequency response10Hz - 100kHz ± 1db
Input sensibility500mV
Output level2V
Preamplifier gain12dB
SNR> 88dB
Distorsion< 0.05%
Remote control
Display screen
Power supplyAC 220V 50hz (Fuse specification : T500mAL 250V)
Standby power consumption< 1W (CE standard)
Dimensions430 x 48 x 280 mm
Weight4kg
Package1x SilkLine ZUKI I
1x IR remote control
1x Power cable
InputAES/EBU
DAC / ADC ChipAD1955
Max sampling rate192kHz
ClassN/A
Remote ControlYes
Refurbished GradeGrade B
Refurbished product - Grade B Silkline's Zuki I combines the functions of preamplifier and DAC. The preamplifier function has a balanced...
