By buying this product you get 27 loyalty points
Refurbished product - Grade B
2 small snags on the top of the unit.
The Singxer UIP-1 Pro is a small, high speed (480Mbps), low noise (20µs) USB 2.0 isolator with a 2kvRMS isolation voltage. It also supports USB 1.0 and 1.1 and works simply by plug and play. In addition, it is equipped with ESD protection up to 15000V IEC (air-gap discharge). It is equipped with a USB-B input operating at 5V and a USB-A output with a maximum output current of 1V. The power supply connector is a Jack DC 5.5/2.1mm and accepts 6V to 9V DC voltages (7.5V recommended).
Product type | USB isolator |
Input | 1* USB-B 2.0 |
Output | 1* USB-A 2.0 |
Supported USB standards | 1.0 1.1 2.0 |
Max bandwidth | 480Mpbs |
Output current | 1V |
Isolation voltage | 2kV RMS |
Output noise | 20µV |
Plug and play |
Dimensions | 112*72*26mm |
Color | Black |
Gross weight | 0.45kg |
Net weight | 0.2kg |
Package | 1* Singxer UIP-1 Pro 1* Male USB-A to male USB-B cable 1x Power adapter |
