Refurbished product - Grade B
Faded chassis color (see last photo).
DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512
SMSL offers with the SU-6 a powerful and affordable DAC, benefiting from a careful design guaranteeing an accurate sound reproduction.
At the heart of the SU-6 is a digital-to-analog conversion chip that converts audio signals with great efficiency. This chip is widely recognized by HiFi enthusiasts. Taking advantage of the HyperStream II 32bit architecture and the Time Domain Jitter Eliminator technology, the ES9038Q2M DAC offers a very clear and transparent reproduction. It also supports high resolution audio streams.
Another strong point of the SU-6 is its second generation USB XMOS interface. This one allows to take advantage of a USB-C input able to support high sampling rates, up to PCM 32bit 768kHz and DSD512, for a sound of an incredible fidelity.
Embedding a Bluetooth 5.0 receiver from Qualcomm, the SU-6 allows you to broadcast your music remotely, from a smartphone or a tablet for example. Moreover, the SU-6 is compatible with the high quality transmission codecs aptX, aptX HD and LDAC, for a restitution equal or superior to CD quality, in wireless.
The whole device benefits from a beautiful design, using only audio components. For example, there are four dual OPA1612 PDUs, a clock processing circuit for low jitter and an integrated low noise power supply.
Product type | DAC |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth |
Output | 1x Stereo RCA |
DAC chip | ESS ES9038Q2M |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
USB Interface | XMOS |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
USB Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX Linux |
USB Transmission | Asynchronous |
THD+N | 0.0001% (-120dB) |
Dynamic range | 125dB |
SNR | 125dB |
Output impedance | < 10Ω |
Consumption | 5W |
Standby consumption | < 0.5W |
Dimensions | 140 x 105 x 28mm |
Weight | 350g |
Color | Black |
Power cable | Included |
Input | USB |
Input | Optical |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
Networking | No |
Remote Control | Yes |
Refurbished Grade | Grade B |
