Refurbished product - Grade A
Slight cosmetic defect (see last photo)
The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable of driving headphones and IEMs with impedances from 16 to 32 ohms. Added to this is bi-directional Bluetooth 5.2 functionality, enabling a wireless signal to be received, for example, from a smartphone with streaming platforms, or sent wirelessly to a Bluetooth speaker. In addition, a USB-A (USB Disk) input lets you connect a USB stick, and accepts a wide range of formats: FLAC, APE, WAV, AAC. The whole unit is powered via USB-C port and features a 2000mAh battery for 6h autonomy.
A special feature of the Thinkya R01 CD player is its two-way Bluetooth capability. Not only can it act as a Bluetooth receiver, but also as a transmitter. This can be particularly useful for people with wireless speakers.
A USB port lets you use a USB stick as a source, and accepts high-definition formats: FLAC, APE, WAV, AAC.
The Thinkya R01 is powered by a 5V/1A DC USB-C port. In addition, a 2000mAh battery provides up to 6 hours of autonomy.
This CD player has a wooden body for a very attractive effect. There's also a fader-operated digital volume control.
An infrared remote control is supplied for a pleasant user experience. Tone control of bass and treble is available via the remote control.
1 | CD player |
2 | Control buttons |
3 | Volume control |
4 | Screen |
5 | Power on |
6 | Optical Toslink output |
7 | USB-A input (USB Disk) |
8 | Jack 3.5mm headphone output |
9 | Jack 3.5mm line output |
10 | USB-C charging port |
Type de produit | Lecteur CD et de fichiers audio USB |
Processor | SILAN SC6137D |
Inputs | CD player 1x USB-A (USB Ddisk) Bluetooth |
Outputs | 1x Optical Toslink 1x Line output 3.5mm jack 1x 3.5mm jack headphone output Bluetooth |
Bluetooth version | Bluetooth 5.2 bidirectional |
Supported formats | CD : CD-DA, CD-R, CD-RW, MP3 USB : FLAC, APE, WAV, AAC |
Supported sample rates | PCM up to 16bit 48kHz |
SNR | > 80dB |
Recommanded headphone output impedance | 16-32Ω |
Tone control | Treble : ±10dB Bass : ±10dB |
Power supply | 5V DC 1A via USB-C |
Standby consumption | < 0.5W |
Battery | 2000mAh |
Full battery charge time | 3h |
Battery life | 6h |
Dimensions | 195 x 160 x 43mm |
Weight | 630g |
Package | 1x Thinkya R01 1x USB-A to USB-C cable 1x 3.5mm jack to 3.5mm jack cable 1x IR remote control |
