[GRADE A] TOPPING CENTAURUS Balanced R2R DAC Black
-5%
Refurbished product - Grade A
Topping has collaborated with Holo Audio to design its new Centaurus balanced R2R DAC. This new high-performance device is based on the use of an ALTERA MAX II CPLD and no less than 8 R2R resistor networks in a balanced configuration. It features three operating modes to adapt to each source: NOS, OS and BEST.
Reduced price!
Reference : 20566
Refurbished
Limited special offer
999,00 €tax incl.
-5%
949,00 €tax incl.
790,84 € tax excl.
This product is temporarily unavailable.
Cardboard box very slightly damaged.
Topping x Holo Audio Centaurus Balanced R2R DAC XMOS XU316 Bluetooth 5.1 LDAC PCM 32bit 768kHz DSD512 Black
TOPPING CENTAURUS picture
Topping has collaborated with Holo Audio to design its new Centaurus balanced R2R DAC. This new high-performance device is based on the use of an ALTERA MAX II CPLD and no less than 8 R2R resistor networks in a balanced configuration. It features three operating modes to adapt to each source: NOS, OS and BEST. Added to this is Bluetooth 5.1 functionality for extremely reliable and stable wireless transmission, thanks to the Qualcomm QCC5125 chip and support for high-resolution codecs: aptX, aptX Adaptive, aptX HD and LDAC (24bit 96kHz). Key features also include a new 10-band equalization algorithm for a wide range of sound reproduction possibilities.
The Centaurus benefits from a complete connectivity interface with balanced XLR and single-ended RCA outputs (variable and fixed), as well as numerous digital inputs: USB-B, Toslink optical, coaxial, AES/EBU, I2S via HDMI. The user experience is further enhanced by the Aurora UI interface, as well as an attractive 2” color display on the front panel and a remote control.
CENTAURUS TOPPING benefits
Topping x Holo Audio Centaurus: high-performance R2R DAC
Centaurus is based on the use of no less than 8 R2R resistor networks in a totally balanced configuration. Four resistor networks are dedicated to DSD decoding, while the 4 networks on the other side of the PCB are entirely dedicated to PCM decoding. All this is controlled by an ALTERA MAX II CPLD for optimum results. This CPLD also improves clock signal processing, reducing jitter to as low as -150dB. The I/V circuit developed by Topping enables the R2R DAC stage to be used to its full potential, while maintaining low distortion and noise levels. Ultra high-performance, it supports sampling rates up to PCM 32bit 768kHz and DSD512.
Photo of the R2R circuit of the CENTAURUS TOPPING DAC
Topping x Holo Audio Centaurus: OS/NOS/BEST modes
Topping Centaurus offers 3 operating modes: Oversampling mode, non-oversampling mode and Best mode, the last one allowing the DAC to automatically select the best oversampling rate according to the source and the DAC's performance, in order to preserve the quality of the final sound rendering.
OS MODE: This mode applies oversampling to the digital signal to minimize quantization errors, reduce noise and obtain better SNR/DNR for superior audio performance. Several oversampling rates are available and selectable to suit different source types and user preferences.
NOS MODE: This mode bypasses oversampling to decode the original source signal for the most authentic reproduction.
TOPPING CENTAURUS operating modes
Topping x Holo Audio Centaurus: 10 bands of parametric equalization
Topping has developed a new algorithm and software that allows you to customize up to 10 frequency bands independently. These new tools enable fine-tuning of the frequencies, gain and bandwidth of each curve. In addition, the software supports the import of target curves, and the saving of different profiles for rapid tuning.
CENTAURUS TOPPING parameters
Topping x Holo Audio Centaurus: Bluetooth 5.1
The Topping Centaurus DAC benefits from a QCC5125 Bluetooth receiver chip, enabling it to support the following high-resolution codecs: AAC, SBC, aptX, aptX Adaptative, aptX HD and LDAC (24bit/96kHz). The result is reliable, stable wireless transmission with resolution beyond the CD standard.
Bluetooth
Topping x Holo Audio Centaurus: USB plug and play XMOS XU316
The XMOS XU316 USB interface offers plug and play compatibility with numerous OS such as Windows, MAC OS, LINUX, IOS and Android. However, use with Windows for ASIO applications requires a driver. The USB input supports up to PCM 32bit 768kHz and DSD512.
Plug and play
Topping x Holo Audio Centaurus: Different output modes
The Centaurus features one RCA and one balanced XLR output. You can use just one output, or use both outputs simultaneously. This makes it possible to use two different sound systems at the same time, for example. In addition, the outputs can be configured in fixed or variable mode, with 4V or 5V for the XLR output and 2V or 2.5V for the RCA output. Variable mode allows you to adjust volume and use the Centaurus as a preamplifier directly coupled with active speakers, for example.
Topping x Holo Audio Centaurus: I2S input via HDMI
The Centaurus I2S input via HDMI also supports sampling rates up to PCM 32Bit 768kHz and DSD512. It is also compatible with numerous I2S and digital interfaces.
Make sure that the I2S HDMI pin definition on the Centaurus DAC matches the pin definition on the source device.
CENTAURUS TOPPING I2S HDMI input
Topping x Holo Audio Centaurus: Aurora UI interface
You can access the Aurora user interface via the 2” display on the Centaurus front panel. It features 9 different display types, including a Vumeter, to delight the greatest number of users.
Aurora UI interface
Topping Centaurus overview
CENTAURUS TOPPING at a glance
1Balanced XLR output
2Single-ended RCA output
3I2S input via HDMI
4Coaxial input
5Optical Toslink input
6Bluetooth antenna
7USB-B input
8AES/EBU input
9Trigger IN/OUT
10IEC power supply / Power switch
Topping CENTAURUS test by Audio Science Review (Amir)
The objective performance of the Centaurus seems to be the best that can be achieved with R2R technology. Topping offers its DAC ultra-low noise, high-quality equalization and packaging.
Tefchnichal characteristics
Product typeDAC R2R
Resistance networksx8
ArchitectureBalanced
USB interfaceXMOS XU316
Bluetooth chipQCC5125
Iinputs1x USB-C
1x I2S via HDMI
1x Optical Toslink
1x Coaxial
1x AES/EBU
Bluetooth
Outputs1x Single-ended RCA
1x Balanced XLR
Other connectors1x Trigger in
1x Trigger out
Supported sample ratesUSB, I2S HDMI: PCM 32bit 768kHz, DSD512
Toslink optical, SPDIF coaxial, AES/EBU: PCM 24bit 192kHz
Supported bluetooth codecsAAC, SBC, aptX, aptX Adaptative, aptX HD, LDAC (24bit 96kHz)
Operating modesOS/NOS/BEST
Output modesFixed or variable
USB compatibilityWindows 10/11
Mac OSX
Linux
IOS/Android
PEQ10 bands
Remote
RCA output parameters (USB in 96kHz)
THD+N (A-WT)< 0.00005% @ 1kHz
THD+N (NO-WT 90kBw)< 0.00005% @ 20Hz-20kHz
SNR (A-WT)126dB @ 1kHz
Dynamic range (A-WT)126dB @ 1kHz
Frequency response20Hz-20kHz (±0.6dB)
20Hz-40kHz (±2.2dB)
Output level2.1Vrms @ 0dBFS (mode 4V)
2.6Vrms @ 0dBFS (mode 5V)
Noise (A-WT)< 1.2uVrms
Crosstalk-121dB @ 1kHz
Channel balance0.3dB
Output impedance50 ohm
XLR output parameters (USB in 96kHz)
SNR (A-WT)130dB @ 1kHz
Dynamic range (A-WT)130dB @ 1kHz
20Hz-40kHz (±2.2dB)
Output level4.2Vrms @ 0dBFS (mode 4V)
5.2Vrms @ 0dBFS (mode 5V)
Noise (A-WT)< 1.4uVrms
Crosstalk-130dB @ 1kHz
Channel separation0.3dB
Outpout impedance100 ohm
Power supply110-240VAC 50/60Hz
Dimensions220 x 160 x 45mm
Package1x DAC R2R Topping Centaurus
1x Remote control
1x Bluetooth antenna
1x USB-A to USB-B cable
1x Power supply cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Refurbished GradeGrade A
[GRADE A] TOPPING CENTAURUS Balanced R2R DAC XMOS XU316 Bluetooth 5.1 LDAC PCM 32bit 768kHz DSD512 Black
Refurbished product - Grade A Topping has collaborated with Holo Audio to design its new Centaurus balanced R2R DAC. This new high-performance...
