Refurbished product - Grade A
Product in good condition.
Streamer WiFi AirPlay 2 Multiroom Bluetooth 5.0 24bit 192kHz
The WiiM Mini is a small and extremely versatile network player, ideal for converting a conventional audio system into a connected system. It will allow you to stream your music remotely via WiFi, Airplay 2 or Bluetooth 5.0.
WiiM Mini
WiiM Pro
WiiM Pro Plus
Ethernet
Yes
Yes
DAC
PCM5121
PCM5121
AKM AK4493SEQ
Analog Out SNR
106dB
106dB
121dB
Analog Out THD+N
-92dB (0.0025%)
-92dB (0.0025%)
-113dB (0.00023%)
ADC
Fixed 16bit 48kHz
Fixed 16bit 48kHz
Up to 24bit 192kHz
Chromecast audio
Yes
Yes
Group with Nest speakers and Display
Yes
Yes
Group with Echo speakers and Display
Yes
Yes
Yes
Alexa multiroom with UHD
Yes
Yes
Group with HomePods
Yes
Yes
Yes
Alexa support
Yes
Yes
Yes
Google support
Yes
Yes
Siri support
Yes
Yes
Yes
Group with WiiM or Linkplay devices
Yes
Yes
Yes
AirPlay 2
Yes
Yes
Yes
AirPlay Cast
Yes
Yes
DLNA
Yes
Yes
Yes
Roon
Yes
Yes
Spotify Connect
Yes
Yes
Yes
TIDAL Connect
Yes
Yes
Yes
Gapless playback
Yes
Yes
Yes
10-band graphic EQ
Yes
Yes
Yes
Linkplay music streaming platform
Yes
Yes
Yes
CPU
Dualcore A7
Quadcore A53
Quadcore A53
DRAM
128MB
512MB
512MB
Flash
128MB
512MB
512MB
Inputs
AUX
Line, Optical
Line, Optical
Outputs
AUX, Optical
Line, Optical, Coaxial
"Bit-perfect" is a term commonly used in audio. It is used to describe a player that can play a file without making any changes to it.
For example, if your player plays a 24bit/192kHz Hi-Res file on Qobuz, the Digital output will offer 24bit/192kHz. Just as if the music file played is a 16Bit/44.1kHz, the Digital output will offer 16Bit/44.1kHz, without any modification. A true 1:1 ratio (Input / Output).
This is what we call a real Bit-Perfect playback, the closest to the musical reality of the song played.
The WiiM Mini supports the Apple AirPlay2 wireless transmission protocol, allowing you to not only easily stream your music from an Apple device, but also stream your music to multiple audio devices at once.
The WiiM Mini is compatible with Amazon Alexa and Apple Siri voice assistants. This means you can easily control your network player via your voice assistant.
The WiiM Mini's built-in multiroom feature allows you to stream your music throughout your home in 3 different modes. If you use an Apple product, you can use Airplay 2 to set up your multiroom system. If you are using an Amazon product, you can use AVS Multiroom technology. Finally, WiiM also provides an application to easily control your multiroom installation from your smartphone.
The WiiM Mini is compatible with many streaming services and web radios, such as Spotify, Tidal, Qobuz, Deezer, Amazon Music or TuneIn. You can enjoy your favorite music services and stream them wirelessly to your audio system. And if you want to connect other audio devices to your WiiM Mini, it has an auxiliary input.
With the WiiM Mini you can stream your music directly from the Spotify Connect and Tidal Connect streaming services, without using the WiiM Home application.
WiiM offers its free WiiM Home mobile app for iOS and Android to easily control all your WiiM devices connected to your network.
Product type | Streamer |
Inputs | WiFi Bluetooth 5.0 1x Jack 3.5mm |
Outputs | 1x Jack 3.5mm 1x Optical Toslink |
Wirelles connectivity | WiFi EEE 802.11a/b/g/n/ac 2.4G WiFi EEE 802.11a/n/ac 1x1 5G Bluetooth 5.0 |
Supported sampling rates | Up to 24bit / 192kHz |
Line input level | 1Vrms |
Output power | Line in to line out : 2Vrms Bluetooth to line out : 2Vrms Line in to SPDIF out: -3dBFS Bluetooth to SPDIF out: 0dBFS |
THD+N | Line in to line out : 0.009% Bluetooth to line out : 0.05% Line in to SPDIF out : 0.005% Bluetooth to SPDIF out : 0.005% |
SNR | Line in to line out : 102dB Bluetooth to line out : 103dB Line in to SPDIF out : 105dB Bluetooth to SPDIF out : 297dB |
Crosstalk | Line in to line out : -106dB Bluetooth to line out : -107dB Line in to SPDIF out : -103dB Bluetooth to SPDIF out : -364dB |
Dynamic range | Line in to line out : 96dB Bluetooth to line out : 121dB Entrée ligne vers sortie SPDIF : 97dB Bluetooth to SPDIF out : 213dB |
Supported audio codecs | MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG |
Compatible streaming services, web radios and protocols | Spotify Deezer Qobuz Amazon Music Tidal Pandora Napster Apple Music TuneIn iHeartRadio LinkPlay Radio Spotify Connect Tidal Connect Local Network Shares (NAS) |
Compatible voice assistants | Alexa Siri |
Supply voltage | 5VDC 1A |
Package | 1x WiiM Mini 1x USB-A to USB-C 1x Stereo RCA to Jack 3.5mm cable 1x Jack 3.5mm cable 1x Optical Toslink cable |
Input | Bluetooth |
Input | Jack 3.5mm |
Input | WiFi |
Output | Jack 3.5mm |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Color | Black |
Remote Control | No |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Qobuz |
Refurbished Grade | Grade A |
