Refurbished product - Grade A
Slightly damaged box.
Portable Balanced USB DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256
With this new product XDUOO pushes the performance of their portable DACs for better reduction of harmonic distortions, noise and better SNR. Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL MAX also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
The Link2 BAL MAX features two CS43131 DAC chips, one for each channel, offering excellent audio stream decoding performance and supporting high resolution streams, up to 32bit 384kHz PCM and DSD256. This design allows the Link2 BAL MAX to achieve an SNR of 128dB for clear and accurate sound reproduction. In addition, the converter and amplifier chips are separately powered to minimize distortion and noise at the output. The Link2 BAL MAX obtains a reduction in the rate of harmonic distortion and noise (THD+N) of less than 0.001@1kHz.
The amplifier stage uses a TI TPS65133 chip, offering a high efficiency of 85% while maintaining low power consumption. It is thus able to develop a comfortable power with a beautiful dynamic.
The xDuoo Link2 BAL MAX, versatile and powerfull, has a double headphone output to adapt to all listening equipment. There is a balanced output on 4.4mm jack and a single-ended output on 3.5mm jack.
The Link2 BAL MAX is covered with 2.5D double-sided glass glazing, the body of the DAC is manufactured using the CNC process allowing a smooth surface and no visible screws. The USB Type C port has been adjusted so as not to let dust through when plugged in. These manufacturing details make it a simple, elegant and robust product.
1 | Play/Pause button |
2 | Volume - |
3 | Volume + |
4 | UAC Mode |
5 | Power mode |
Product type | Portable balanced USB DAC and headphone amplifier |
DAC chip | 2x CS43131 |
Input | 1x USB-C |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm |
Output power | Single-ended : 200mW @ 32Ω Balanced : 270W @ 32Ω |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
Frequency response | 20Hz - 20kHz (±0.5dB) |
THD+N | Single-ended : 0.001% @ 1kHz Balanced : 0.0007% @ 1kHz |
SNR | Single-ended : 124dB Balanced : 128dB |
Crosstalk | Single-ended : ≥ 79dB Balanced : ≥ 122dB |
Dimensions | 63 x 23.5 x 13mm |
Net weight | 28g |
Package | 1x xDuoo Link2 BAL MAX 1x USB-C Cable 1x USB-C to Lightning cable 1x Female USB-C to male USB-A adapter |
Input | USB |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Gray |
Class | Class D / T |
Networking | No |
Remote Control | No |
Refurbished Grade | Grade A |
