Refurbished product - Grade A
Box slightly damaged. Very slight traces of use.
The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification stage and a 6N5P tube for its buffer. The input is on RCA connectors and the headphone outputs are 6.35mm jack and 4.4mm balanced jack. The TA-26S also has a pre-out RCA output to accompany an external amplifier or active speakers. All the outputs also benefit from the volume control of the device. Finally, all the components are integrated in a sturdy grey aluminum alloy case.
Compared to the XDUOO TA-26 wich has one jack ouput of 6.35mm, the XDUO TA-26S has 2 heaphones jack output of 4.4mm balanced and 6.35mm, also it has a backside power switch.
Product type | Headphone amplifier |
Tubes | Preamplifier : 6N8P Buffer : 6N5P |
Input | 1x Stereo RCA |
Outputs | 1x Jack 4.4mm balanced headphone output 1x Jack 6.35mm headphone output 1x Stereo RCA |
Output power | 500mw @ 600/300Ω |
Frequency response | 10Hz-30kHz (±0.5dB) |
Gain | +16dB |
SNR | 110dB |
THD+N | ≤ 0.1% (1kHz) |
Recommended headphone impedance | 60-600Ω |
Supply voltage | 220-240VAC (Power cable included) |
Dimensions | 250 x 110 x 160cm |
Weight | 3.9kg |
Color | Gray |
Input | RCA |
Output | RCA |
Output | Jack 4.4mm |
Output | Jack 6.35mm |
Color | Gray |
Class | Tube amp |
Remote Control | No |
Refurbished Grade | Grade A |
