Linear power supply module by Audio-GD. Operates in pure class A with positive or negative dual output.
Uses exclusively high quality components (Nover, WIMA capacitor and Toshiba transistors) for an extremely neutral impact on the sound. This module is ideal for circuit that are very sensitive to power noise and need little current such as DA, DAC, preamplifier stage, OPA... etc.
The operation in pure class A has a high input impedance and low output impedance. This allows for a very fast output response while maintaining an extremely low current.
If the input voltage is at its maximum value (shown in the table below), please change heatsinks or mount the transistors directly on the chassis.
Type | Power supply Pure class A |
Idle current | 80mA |
Temperature range | 0-85°C |
Dimensions | 89x51x45mm |
Voltage range (max current) Input | 15-24VDC (80mA) 15-22VDC (120mA) |
output voltage | Double +12V ou double -12V |
Input | Solder pad |
Output | Solder pad |
Output voltage (V) | 12.0 |
Output current (A) | 0.1 |
Input voltage (V) | 24.0 |
Input voltage (V) | 22.0 |
Input voltage (V) | 15.0 |
Power Supply | Linear |
