BEATECHNIK x LHY AUDIO Power Supply Module Kit for Bluesound Node X / N130
This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node X and N130 products.
Reference : 18552
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 25-02-2025.
BEATECHNIK x LHY AUDIO Power Supply Module Kit Filter Power Supply Module Kit for Bluesound Node X / N130
Photo of Filter Power Module Kit for Bluesound Node X / N130 by BEATECHNIK x LHY AUDIO
This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node X and N130 products. This filtered power supply improves the performance of the Bluesound Node X and Bluesound N130 network players, as using a filtered power supply rather than a switch-mode power supply offers many advantages, not least a great improvement in the sound reproduction quality of your devices.
This power supply module features three C-L/C-L/C-L/C filter stages and is made up of numerous capacitors and inductors. The input is on a DC 5.5/2.1mm connector and accepts DC 5V. The wiring supplied is silver-plated.
Removing or changing the power supply of the Bluesound Node X / N130 invalidates the warranty.
Product typeFiltered power supply module kit
Supply voltage/current5V DC
ConnectorDC 5.5/2.1mm
InputJack DC 5.5/2.1mm
OutputPCB Connector
Output voltage (V)NC
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower supply filter
Node 2021
Changement de l' alimentation en une demi heure enfantin
Restitution sonore transcendai tout est plus naturel équilibré aucun regret
This review has been posted for BEATECHNIK x LHY AUDIO Filter Power Supply Module Kit for Bluesound Node X / N130
This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node...
