IAN CANADA LINEARPI PRO DUAL Linear Power Supply Module 5V + 3.3V
The LinearPi Pro, an evolution of the Linear Pi MKII, is an ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38C. This regulated linear power supply is able to deliver 3 different voltages: 5V(default), 3.3V and 12V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.
By buying this product you get 25 loyalty points
Reference : 19915
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 25-04-2025.
Ian Canada LinearPi Pro Dual Ultra-Low Noise Linear Power Supply Module 5V + 3.3V
IAN CANADA LinearPi Pro picture
The LinearPi Pro, an evolution of the Linear Pi MKII, is a IAN CANADA ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38C. This regulated linear power supply is able to deliver 5V and 3.3V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.
Key points and improvements of the IAN CANADA LinearPi Pro :
  • 5A continuous output current
  • Ultra-low output impedance of 2.5mOhm
  • Very low noise level 0.8uV
  • Parallel output architecture
  • 4-layer PCB with double copper thickness and additional shielding layers
  • Total filtering capacity 29080 uF
  • Large heat sink
  • SMT PCB assembly process
  • Several LinearPi Pros can be grouped into a large power supply system using the integrated isolated master/slave on-off control signal chain
LinearPi Pro
Linear Pi
Output current
5A
2.5A
Total filtering capacitance
29080uF
13640uF
Architecture
Parallel power stages
Single power stage
PCB
Four layers double thickness copper high current PCB with two additional shield layers
Two layers double thickness copper high current PCB
Ultra low noise
0.8uV RMS rated
Actual noise could be even lower because of the parallel power output stages and the additional shield layers
0.8uV RMS rated
Heatsink
25 x 50 x 50mm
15 x 50 x 50mm
Schottky rectifiers
High speed, ultra-low drop
High speed
Ian Canada LinearPi Pro Dual: excellent transient response
One of the key features of the Linear Pi Pro Dual is its transient load response. Indeed, when the load current varies from 1A to 5A, the noise level remains extremely low and the output voltage drop does not exceed 10mV. With output impedance limited to 2.5mOhm (@1kHz), the linear Pi Pro can be considered one of the best-performing low-noise linear power supplies on the market.
IAN CANADA LinearPi Pro transient response curve
Schéma Ian Canada LinearPi Pro Dual
Product typeLinear power supply module
Output voltage5V DC
3.3V DC
Output current5A
Rated noise0.8µV
Recommended input voltage3.3V configuration: 5VDC
5V configuration: 9VDC
12V configuration: 15VDC
Transformer recommendation chart
Voltage configurationWorking currentTransformer P/N or equivalent
3.3V0-5A1182Q6
0-2.5A1182N6 or 1182L6
5V0-5A1182Q6
0-2.5A1182N6 or 1182M9
Dimensions132 x 115mm
Mouting holes spacing115.5 x 108mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)5.0
Input voltage (V)9.0
Power SupplyLinear
IAN CANADA LINEARPI PRO DUAL Ultra-Low Noise Linear Power Supply Module 5V + 3.3V
The LinearPi Pro, an evolution of the Linear Pi MKII, is an ultra-low-noise linear power supply capable of delivering high currents. This is the...
