IAN CANADA LINEARPI MKII SOLO Ultra-Low Noise Linear Power Supply Module 5V / 3.3V / 12V 2.5A
The Ian Canada Linear Pi Solo MKII  is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application.
Reference : 17611
89,00 €tax incl.
74,17 € tax excl.
Ian Canada LinearPi solo MKII
IAN CANADA LinearPI MKII SOLO Ultra-Low Noise Linear Power Supply Module 5V / 3.3V / 12V 2.5A
The Ian Canada Linear Pi Solo is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application. Several LinearPi modules can be combined to create a larger power supply system. This module can also be easily upgraded to a supercapacitor power supply by combining it with the IanCanada UcConditioner.
Points clés :
  • Linear power supply 5VDC, 3.3VDC or 12V 2.5A
  • Ultra low noise level 0.8µV
  • Ultra low output impedance
  • High-speed, high-current, low-noise Schottky rectifiers with optional shunt capacitors
  • Integrated ON/OFF control logic with on-board or external ON/OFF switch
  • Multiple LinearPi's can be grouped together to create a complete power system, using the isolated master/slave control signal chain
  • Quick and easy upgrade to a supercapacitor power supply with the UcConditioner module (sold separately)
  • Continuous AC input mode for the best possible sound quality
  • Optional Kelvin sensor input for better performance
  • Deals with the piezoelectric noise of the MLCC
  • PCB with 2 ounce double layer copper circuitry for ultra low ESR
  • Input 6-9-12V AC or 9-12-15V DC
  • Robust SMT design
Ian Canada LinearPi Module Alimentation Linéaire Ultra Faible Bruit 5V / 3.3V 2A
The improvements of the LINEAR PI version MKII
  • 5V, 3.3V and 12V configuration pure linear DC power supply, 2.5A rated output current
  • Two stages ultra-low noise soft start feature great for both digital and analog application
  • Total 13,200uF enhanced high capacitance high current ultra-low ESR filtering network for a significant improvement
  • Standard 5*20mm high performance glass fuse
  • Bigger and stronger ON/OFF switch
Product typeLinear power supply module
Output voltage12V DC
5V DC
3.3V DC
Output current2.5A
Noise0.8µV
Input voltage3.3V configuration: AC6V or DC9V
5V configuration: AC9V or DC12V
12V configuration: AC12V or DC15V
Dimensions132 x 56mm
Mouting holes spacing114.5 x 49mm
3.3V configuration: AC6V or DC9V 5V configuration: AC9V or DC12V 12V configuration: AC12V or DC15V
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output voltage (V)3.3
Output voltage (V)12.0
Output current (A)2.5
Input voltage (V)6.0
Input voltage (V)12.0
Input voltage (V)9.0
Power SupplyLinear
Bon produit
Achetée pour appliquer un principe énoncé par Mr. He Qinghua sur la pureté du son...
Cela alimente un SONOS port utilisé comme streamer. Il est connecté sur l'entrée 1 d'un Master 7. Cette configuration Insupportable avant le changement d'alimentation, Remplace maintenant avantageusement mon pc et sa liaison via usb avec Amanero combo 384. Cette configuration est nettement plus constante et fiable que celle utilisant le pc avec Fidelizer et d'autres logiciels onéreux soit disant high end.
This review has been posted for IAN CANADA LINEARPI MKII SOLO Ultra-Low Noise Linear Power Supply Module 5V / 3.3V / 12V 2.5A
The Ian Canada Linear Pi Solo MKII  is an ultra low noise power supply module delivering high quality, high current, versatile and...
