LDOVR TPS7A4700 Ultra Low Noise Regulated Linear Power Supply 1.4V / 20.5V 1A
This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input voltage range is from 3 to 25VDC or 3 to 18VAC. Its output is adjustable in 0.1V steps, from 1.4V to 20.5V 1A, using solder pads on the PCB.
Reference : 16285
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 22-04-2025.
LDOVR TPS7A4700
LDOVR TPS7A4700 Module Alimentation Linéaire Régulée Ultra Faible Bruit 1.4V / 20.5V 1A
This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input voltage range is from 3 to 25VDC or 3 to 18VAC. Its output is adjustable in 0.1V steps, from 1.4V to 20.5V 1A, using solder pads on the PCB:
LDOVR TPS7A4700: Output voltage adjustment diagram
Please set the desired voltage before soldering the rail to the PCB.
Product typeRegulated linear power supply
Input supply voltage3VDC to 25VDC
3VAC to 18VAC
Any-Out™ voltage modesUser programmable output via solder pads on the PCB
Output voltage range : 1.4V to 20.5V (0.1V step)
Output current1A
Output noise4µVrms (10Hz, 100kHz)
Ripple rejection82dB (100Hz)
≥55dB (10Hz, 10MHz)
Dropout voltage307mV @ 1A
ProtectionsFixed current limit
Thermal protection
Operating temperature voltage-40°C / +125°C
External feedback option
PCB Dimensions30 x 60mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)20.5
Output voltage (V)1.4
Output current (A)1.0
Input voltage (V)3.0
Input voltage (V)25.0
Power SupplyRegulated Linear Power Supply
This LDOVR TPS7A4700 regulated linear power supply module provides an extremely low noise level measured at only 4µvrms. Its input...
