LHY AUDIO A1943 Low Noise Linear Power Supply Module 2SA1943 3.3-15V DC
This LHY Audio low noise linear power supply module offers a very good price/performance ratio. It integrates a D15XB high power diode bridge, a LM317T and TL431 voltage regulator as voltage reference and a Toshiba 2SA1943 high current PNP transistor for its output.
Reference : 17439
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 22-04-2025.
LHY Audio Linear Power supply module
Low noise 2SA1943 3.3-15V DC
LHY Audio Module d'alimentation linéaire faible bruit 3.3-15V DC
This LHY Audio low noise linear power supply module offers a very good price/performance ratio. It integrates a D15XB high power diode bridge, a LM317T and TL431 voltage regulator as voltage reference and a Toshiba 2SA1943 high current PNP transistor for its output. This ensures excellent linearity and stability. The module provides a basic output voltage of 12VDC and can be adjusted over a range of 3.3V to 15V DC.
Input voltageOutput voltage
9VAC5VDC
12VAC9VDC
15VAC12VDC
18VAC15VDC
It is strongly recommended that the module be associated with a heat sink, especially from a load current of 1A.
Product typeLinear power supply module
Output voltageDefault: 12V DC
Adjustment range: 3.3~15V DC
Diode bridgeD15XB
Voltage regulatorsLM317T
TL431
TransistorToshiba 2SA1943
Capacitors4* Nichicon 4700µV 40V
8* Rubycon 680µV 35V
Output currentRated: 5A
Max : 10A (large heat sink required to achieve this value)
Dimensions100*70*46mm
Mounting holes spacing90*60mm
InputSolder pad
OutputSolder pad
Output voltage (V)15.0
Output voltage (V)5.0
Output voltage (V)3.3
Output voltage (V)9.0
Output voltage (V)12.0
Output current (A)NC
Input voltage (V)N/A
Power SupplyRegulated Linear Power Supply
This LHY Audio low noise linear power supply module offers a very good price/performance ratio. It integrates a D15XB high power diode bridge, a...
