LHY AUDIO Linear Power Supply Module IRF9Z34 IRFZ34 25VA 12V
This LHY Audio linear power supply module is designed with quality components, using a Talema 25VA (12.5VA + 12.5VA) transformer and IRF9Z34 and IRFZ34 MOSFET transitors driven by OPA277 precision OPAs.
Reference : 19771
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 22-04-2025.
LHY Audio Linear power supply module IRF9Z34 IRFZ34 25VA +/-12V
Photo of LHY Audio linear power supply module
This LHY Audio linear power supply module is designed with quality components, using a Talema 25VA (12.5VA + 12.5VA) transformer and IRF9Z34 and IRFZ34 MOSFET transitors driven by OPA277 precision OPAs. This power supply also benefits from a balanced circuit. The module receives 230V AC input and outputs +/-12V voltage and 1A current. This LHY AUDIO module is highly recommended for use in DIY projects, as a power supply for a preamplifier module, a DAC module or a power amplifier module, for example.
Overview of the LHY Audio linear power supply module
1230V AC input
2Talema 25VA transformer
3Nichicon 4700uF 40V capacitors
4MOSFET IRF9Z34 and IRFZ34 transistors
5OPAs OPA277
6Capacitor 35V 680uF
7+/-12V 1A output on soldering pad
LHY Audio linear power supply module dimensions
Product typePower supply module
Power supply typeLinear
Input230V AC on VH 3.96 connector (N/G/L)
Output+/-12V on soldering pad (-/0/+)
OPAOPA277
MOSFET transistorsIRF9Z34 and IRFZ34 mosfets
Dimensions138 x 64 x 42mm
Mounting holes56 x 130mm
Weight550g
Package1x LHY Audio linear power supply module
InputVH 3.96mm
OutputSolder pad
Output voltage (V)-12.0
Output voltage (V)12.0
Output current (A)1.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
This LHY Audio linear power supply module is designed with quality components, using a Talema 25VA (12.5VA + 12.5VA) transformer and IRF9Z34 and...
