LHY AUDIO LPS-A6 230V Linear Power Supply Module for EverSolo DMP-A6
The LPS-A6 linear power supply module developed by LHY Audio has been specially designed to improve the power supply stage of the EverSolo DMP-A6 and DMP-A6 Master Edition streamers by replacing the original switching power supply. The LPS-A6, manufactured by LHY Audio, provides the streamer with improved performance.
By buying this product you get 25 loyalty points
Reference : 19889
259,00 €tax incl.
215,83 € tax excl.
LHY Audio LPS-A6 230V Linear Power Supply Module for EverSolo DMP-A6
LHY Audio LPS-A6 : Top view
The EverSolo DMP-A6 / DMP-A6 Master Edition warranty becomes null and void if the power supply is removed or replaced.
To maintain the validity of your warranty, if you have already purchased an EverSolo DMP-A6 / DMP-A6 Master Edition from Audiophonics, we offer to carry out the installation for you, in our workshop. You will be invoiced a fixed fee for this operation, which will be communicated to you by e-mail. To do this, please contact us via the contact form, "Pre-sale" tab, "Technical information - Advice" section.
LHY Audio LPS-A6: Linear power supply
First of all, the LPS-A6 power supply from LHY Audio has the immense advantage of being a linear power supply, which has several advantages over the original decoupled power supply. Firstly, because of the way it works, this type of power supply generates no high-frequency noise, making it naturally quieter and easier to filter. Furthermore, this type of power supply tends to offer a much more stable output voltage with very little fluctuation or ripple, an essential quality in power supplies for HiFi equipment that is very sensitive to this type of disturbance.
LHY Audio LPS-A6 : Power supply details
LHY Audio LPS-A6: Low-noise power supply
In order to offer the quietest possible power supply, LHY's LPS-A6 incorporates two LT3042 ultra-low-noise voltage regulators in a symmetrical architecture, ensuring a noise floor of less than 10μV where the original EverSolo DMP-A6 power supply is measured at 1.222mV.
LHY Audio LPS-A6: Triple shielding of the toroidal transformer
Still with a view to offering the cleanest possible power supply, the toroidal transformer is triple-shielded, protecting it from environmental EMI noise while preventing the transformer's magnetic field from impacting on the audio signal.
LHY Audio LPS-A6: Non-destructive modification
Finally, it's important to note that changing the EverSolo DMP-A6 power supply is non-destructive. In fact, LHY offers a fixing system identical to the original power supply, so you can simply replace it without having to adapt the frame.
Type of productLinear power supply kit for EverSolo DMP-A6 / DMP-A6 Master Edition
Noise levelNo load : <10μV
80% load : <30μV
Supply voltage220-240V AC
Transformer typeIron core
OFC copper winding
Output voltage+12V @2A
-12V @0.5A
Power consumptionStandby : 2W
In use : 25W
Weight0.8kg
Dimensions170 x 72 x 45mm
Package1x LHY Audio LPS-A6
1x 6P cable
1x Screwdriver
1x Allen wrench
1x Pair of gloves
InputNC
OutputNC
Output voltage (V)12.0
Output voltage (V)-12.0
Output current (A)0.5
Output current (A)2.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
2 reviews
génial
Monter hier dans un eversolo dmp6 master édition , montage en 15mn plus in pluay , qualité top packagé complet gant outil. Vidéo sur le net facilement trouvable , pas besoin de mettre de rondelle pour isoler c'est idem que montage origine , attention quand vous basculer le couvercle en avant la fiche pour l'écran et le bouton son très fragile et peuvent casser ( mettre quelque chose pour tenir le capot une fois basculer en avant ) bien éteindre l'appareil et appuyer 20/30s sur le bouton pour vider le courant avant remplacement des alim. Sinon c'est net ! Le gain et immédiat ! Aération de la scène sonore , spacialisation , gain en dynamique , basse plus franche et nerveuse le son et beaucoup plus large et aérien. On gagne un peut en détail . Le gain et a la hauteur de l'investissement . Je ne peut que recommander , je suis encore en rodage mais sur mon système le gain fut aussi haut que lors de l'ajout d'un conditionneur sur l'installation . Je recommande chaudement de plus vous protéger votre système cette alim a un fusible que celle d'origine n'a pas . Pour 250e vous aller améliorer votre matériel et le retour a l'origine n'est plus possible ! Merci Audiophonics pour le vois bien protéger .
This review has been posted for LHY AUDIO LPS-A6 230V Linear Power Supply Module for EverSolo DMP-A6
Très satisfait
Il y a une différence de 140 euros avec la Beatechnik…parce que mieux fini avec de meilleurs composants (dixit Audiophonics),mais sur le papier la LHY à 169 euros à de bien meilleurs résultats…
Pour ma part je la trouve très bien fini,et il y a une amélioration sur le son.
Pour l,instant il faut la roder et je pense que ça devrait encore s’améliorer.
Pas de chauffe.
The LPS-A6 linear power supply module developed by LHY Audio has been specially designed to improve the power supply stage of the EverSolo DMP-A6...
