Power Module Linear LT3042 for XMOS
This linear power supply module is based on an LT3042 and a high-performance A1930 transistor from Toshiba. It benefits from the PSRR architecture dedicated to the power supply of devices that are very sensitive to noise.
Reference : 13972
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 22-04-2025.
Alimentation Linéaire
Linear Power Supply Module LT3042 5V 1A
This linear power supply module is based on an LT3042 and a high-performance A1930 transistor from Toshiba. It benefits from the PSRR architecture dedicated to the power supply of devices that are very sensitive to noise. It is one of the LTC power supply modules well known for their very low noise level. Its construction incorporates a precision voltage reference with a high performance voltage buffer. It can therefore be connected in parallel to further reduce noise, increase output current and split heat sources to avoid hot spots. It can provide a 5V output voltage while maintaining a minimum noise level. It will therefore be recommended to do everything to power all 5V 1A modules, like the USB XMOS / SPDIF interfaces. This power supply module is stable thanks to a Nover 6800µF capacitor.
Dimensions LT3042
Use a 33K resistor to output 3V
3.3V power supply DIY
Product typeLinear power supply module LT3042
Transistors1x Toshiba A1930
Output current (peak)1A
Output current (continuous)500mA
Minimum transformer9VAC
Output voltage0 - 15V
Outputs number1x outpus on screw terminals
RMS Noise0.8µV RMS (10Hz - 100kHz)
Noise2nV/√Hz (@ 10kHz)
PSRR79dB (@ 1MHz
Supply voltage range5V to 20V
Capacitor1x Nover 6800µF 135V DC
Bandwidth1MHz
Low voltage dropout350mV
Dimensions48 x 52.5mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output voltage (V)10.0
Output voltage (V)15.0
Output voltage (V)1.0
Output current (A)1.0
Output current (A)0.5
Input voltage (V)N/A
Power SupplyLinear
This linear power supply module is based on an LT3042 and a high-performance A1930 transistor from Toshiba. It benefits from the PSRR architecture...
