Power Supply DC-DC Converter Module 4-12V DC to +/-8 to +/-18V DC 1.5A
This small regulated power supply module acts as a DC-DC converter. It is indeed able to take a voltage of 4V to 12V DC as an input and then output an adjustable voltage ranging from +/-8V DC to +/-18V DC. By default, the module is set to an output voltage of +/-12V DC.
4.0 / 5
Reference : 14008
9,90 €tax incl.
8,25 € tax excl.
POwer Supply Module
Module d'alimentation Convertisseur DC-DC 4-12V DC vers +/-8 à +/-18V DC 1.5A
This small regulated power supply module acts as a DC-DC converter. It is indeed able to take as input a voltage from 4V to 12V DC (5V DC on the Micro USB) and then output an adjustable voltage ranging from +/-8V DC to +/-18V DC. By default, the module is set to an output voltage of +/-12V DC. The module can be input either on a Micro USB connector (5V DC) or on solder contacts. The output is also to be soldered.
The quality design of the module, which includes low-loss inductors or high-frequency ceramic capacitors with very low resistance and connected in parallel, provides a clean and stable electrical signal, essential for precise and rich sound reproduction.
Product typeDC-DC Converter
Input voltage4-12V DC (5V DC on Micro USB)
Output voltageAdjustable from +/-8V to +/-18VDC (+/-12V DC by default)
Max output current1.5A
Input2 Contacts to solder
1x Micro USB (Max 5V)
Outputs3 Contacts to solder
Dimensions (LxPxH)41 x 41.4 x 15mm
Fixation holes spacing33 x 33mm
Input
  • Solder pad
  • USB
Output
  • Solder pad
Output voltage (V)
  • 10.0
  • 11.0
  • 12.0
  • 13.0
  • 14.0
  • 15.0
  • 16.0
  • 17.0
  • 18.0
  • 8.0
  • 9.0
Output current (A)
  • 1.5
Input voltage (V)
  • 10.0
  • 11.0
  • 12.0
  • 4.0
  • 6.0
  • 7.0
  • 8.0
  • 9.0
Power Supply
  • Voltage converter
Pratique !
Très pratique pour alimenté en + et - avec une batterie ! Peu bruyante lorsqu'il n'y a pas de conversion ou une conversion de faible delta mais à vérifier avec des bancs de mesures labo. En tout cas pour tester des montages audio analogique, c'est parfait.
This review has been posted for Power Supply DC-DC Converter Module 4-12V DC to +/-8 to +/-18V DC 1.5A
This small regulated power supply module acts as a DC-DC converter. It is indeed able to take a voltage of 4V to 12V DC as an input and then output...
