Regulated Linear Power Supply AC-DC LM317 / TL431 24V 1.5A
4.5 / 5
Reference : 14094
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 24-04-2025.
linear regulated power supply 37V DC 1.5A
Linear regulated power supply LM317 TL431
This linear regulated power supply incorporates a high precision linear voltage regulator LM317 and offers an excellent thermal stability. A second reference TL431 regulator significantly increases performance for ideal audio performance.
The filtering is performed using a Gold Nover Audio Grade Capacitor 6800μF 35V and the diode bridge uses Philips resistors BI US high speed.
The module accepts input voltages from 6 to 24V (AC) and covers an output voltage 3.3 to 24V (DC) with a maximum current of 1.5A.
Dimensions
power module dimensions
distances
Module distances supply
All dimensions are in mm
Typelinear regulated power supply
Input Voltage6-24V AC
Output voltage3.3 - 24V DC
Dimensions44 x 77 x39 mm
Mounting holes3 mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)24.0
Output voltage (V)3.3
Output current (A)1.5
Input voltage (V)24.0
Input voltage (V)10.0
Input voltage (V)20.0
Input voltage (V)6.0
Input voltage (V)15.0
Power SupplyRegulated Linear Power Supply
6 reviews
Ottima scheda
Ne ho acquistati due per avere due alimentazioni separate, una a 5 Volt e una a 15Volt.
La scheda è realizzata bene, buoni condensatori e stabilizzatore montato su dissipatore.
Di notevole qualità le morsettiere per il collegamento delle uscite/ingessi
Il prezzo è assolutamente adeguato alla qualità / prestazioni della scheda.
spedizione per l'Italia in tempi davvero rapidi e imballaggio davvero MOLTO BEN FATTO.
Complimenti AUDIOPHONICS
This review has been posted for Regulated Linear Power Supply AC-DC LM317 / TL431 24V 1.5A
Cette alimentation pompe à 1,7Khz
Il faut un oscilloscope pour le voir, mais en l'état il y des impulsions de plusieurs dizaines de mV à 1,7Khz sur la sortie. La correction consistera à mettre une capas très faible entre la sortie et la pin de ref du TL431. Les résistances sont également trop élevées à part la 220ohms : Mauvais design Chinois.
Lp
Société très efficace
Envoi rapide
Produit excellente qualité
Rien a redire
produit conforme
produit arrivé rapidement et conforme a la description .
Wrong specifications
Beware, the capacitor after the diode bridge is 35V, so the specified 33V AC input is way too high. I did not care and learned it the hard way when the capacitor exploded with 32V transformer. The capacitor after the regulator is 25V so maximum DC output 37V is also clearly wrong.
