Dual LME49710 / MJE15032 5-18VDC
This regulated linear power supply module takes advantage of a beautiful design quality to provide a clean electrical signal to your HiFi devices. It takes as input an electrical signal between 2x7V AC and 2x18V AC to output between 5VDC and 18VDC with a maximum output current of 2A. (non continuous)
The module integrates low noise components to ensure very good performance, including two LME49710 operational amplifiers driving two MJE15032 transistors.
Product type | Regulated linear power supply board |
Input voltage range | 2x7V AC - 2x18V AC |
Output voltage range | 5V - 18V |
Max output current | 2A (Continuous recommended < 500mA) |
Operationnal amplifier | 2x LME49710 |
Transistors | 2x MJE15032 |
Dimensions | 81 x 61mm |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 10.0 |
Output voltage (V) | 15.0 |
Output voltage (V) | 18.0 |
Output voltage (V) | 5.0 |
Output current (A) | 0.5 |
Output current (A) | 2.0 |
Input voltage (V) | 10.0 |
Input voltage (V) | 18.0 |
Input voltage (V) | 7.0 |
Input voltage (V) | 15.0 |
Power Supply | Regulated Linear Power Supply |
