Regulated Power supply Module DC IRF610 K246 +/- 5V to 25V 1A
This regulated linear power supply module with field effect transistors IRF610 and IRF9610 without integrated regulators allows a very fast rise time with two filter capacitors of 4700µf under 63V.
Reference : 12112
19,90 €tax incl.
16,58 € tax excl.
To help you choose the right power supply for your projects, we invite you to take a look at this page.
Technical characteristics :
  • Power supply by discrete circuit (IRF610 and IRF9610)
  • 2x 4700µF 63V capacitors
  • 2x 220µF 50V capacitors
  • 4x 56µF 63V capacitors
  • Multi-turn precision adjustable from +5V to 25V
Specifications :
  • AC Voltage input : 6V / 26V
  • DC voltage output : Variable from +/- 5V to 25V ( 1A under 22V )
  • Dimensions : 113 x 68.6 x 42.8mm
  • Mounting holes spacing : 91 x  63mm
  • Weight : 126g
InputScrew terminals
OutputScrew terminals
Output voltage (V)10.0
Output voltage (V)25.0
Output voltage (V)5.0
Output voltage (V)20.0
Output voltage (V)15.0
Output current (A)1.0
Input voltage (V)20.0
Input voltage (V)26.0
Input voltage (V)6.0
Input voltage (V)15.0
Input voltage (V)25.0
Input voltage (V)10.0
Power SupplyRegulated Linear Power Supply
This regulated linear power supply module with field effect transistors IRF610 and IRF9610 without integrated regulators allows a very fast rise...
