DAYTON AUDIO DAX88KP In-Wall Control Keypad for DAX88
New
The Dayton Audio DAX88KP is a flush-mount control panel specially designed for use with the brand's DAX88. This practical control panel gives you complete control of the DAX88.
Reference : 20636
69,90 €tax incl.
58,25 € tax excl.
Dayton Audio DAX88KPIn-Wall Control Keypad for DAX88
Photo of Dayton Audio DAX88KP
The Dayton Audio DAX88KP is a flush-mount control panel specially designed for use with the brand's DAX88. This practical control panel gives you complete control of the DAX88. Up to eight different control panels can be connected to access different control zones. This flush-mount keypad offers various controls such as volume, power, bass, treble, mute and source selection. Each control panel connects via an Ethernet cable to the DAX88HUB Keypad Hub, which allows you to connect eight individual keypad for placement in your home or business.
If you use more than one keypad, the DAX88HUB is required for operation.
Wall-mounted example of the Dayton Audio DAX88KP
Dayton Audio DAX88KP: Zone control
DIP switches on the rear of each control panel are used to select the zone controlled by the keypad. Setting the DIP switches gives the remote control a distinct address which determines the corresponding zone. The control panels do not need to be connected to a specific DAX88HUB socket.
Dayton Audio DAX88KP DIP SWITCH control
Dayton Audio DAX88KP control keypad overview
1Numeric LED Display
2EXT/Mute/PA selection LED
3Volume +/-
4Input selection LED
5Down / Volume - / Treble / Bass / Un-Mute
6Input selection 1-8 (previous)
7IR receiver
8Power On/Off & Mode selection
9Input selection 1-8 (next)
10Up / Volume + / Treble / Bass / Un-Mute
11Bass Up/Down LED
12 Treble Up/Down LED
Product typeIn-wall control keypad for DAX88
Control functionVolume
Zone power
Input selection
Bass
Treble
Mute
ConnectionEthernet RJ45 (Cat5 cable or higher recommended)
Dimensions10.32 x 3.81 x 4.5cm
Depth3.81cm
Package1x Dayton Audio DAX88KP
The Dayton Audio DAX88KP is a flush-mount control panel specially designed for use with the brand's DAX88. This practical control panel gives...
