Infrared remote control RC6 + IR receiver module for Raspberry Pi 3 / Pi 2
3.0 / 5
Reference : 11735
12,90 €tax incl.
10,75 € tax excl.
IR remote control for RPI
IR Remote Control RC6 + IR receiver module for RPI
Télécommande IR pour Raspberry Pi
Here is a RC6 TOSHIBA infrared remote control with its IR receiver for Raspberry Pi 3 or Pi 2. The receiver is directly connectable to the Raspberry's GPIOs, making it an easy-to-use Plug & Play kit.
Of course, you will have to use a software solution on your Raspberry Pi that integrates the LIRC protocol, such as Kodi's OSMC. OSMC is a free and open source multimedia solution based on Linux, created by passionate people for passionate people.
osmc
Simply go to the settings of your software solution and activate IR reception if available. In case the Raspberry Pi GPIO PINs are already in use, discover a detailed and extensive tutorial for setting up an IR remote control for OSMC on the Sunfounder website: IR Remote Controller Configuration for OSMC.
Remote control & receiverInfrared (IR)
IR ReceiverPlug & play on RPI GPIO
Acceptable receiver distanceUp to 8m
Phosphorescent keys-
Dimensions85.7 x 39.7 x 7mm
Weight12g
battery typeCR2025 3VØ 20mm button cell supplied (Available also as accessories)
IR receiver to connect to the Raspberry Pi 3 GPIO pins as shown in the pictures below.
Input
  • IR
Output
  • IR
Color
  • White
Transmission / Reception protocol
  • IR
Fonctionne aussi sous LibreElec 9
Fonctionne sous LibreElec 9. Pour cela, j'ai dû faire deux choses, après avoir glané différentes infos ici et là:
1) ajouter la ligne: dtoverlay=gpio-ir dans le fichier /flash/config.txt (il faut remonter la partition /flash avec les droits d'écriture avant)
2) créer le fichier /storage/.config/lircd.conf trouvé sur le site sunfounder: http://wiki.sunfounder.cc/images/3/35/Lircd.zip
Au final ça fait le job, mais télécommande vraiment très petite et pas du tout ergonomique.
This review has been posted for Infrared remote control RC6 + IR receiver module for Raspberry Pi 3 / Pi 2
