VISHAY DALE CMF55 Resistor 1% 50ppm 1.21 KOhm
Reference : 2895
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 29-04-2025.
Vishay DALE CMF-55
Resistors Vishay Dale CMF55 series
Vishay Dale CMF55 are a serie of very high quality resistors. These components benefit from a virtually null inductance and excellent electronic / thermal stability.
These resistors are indeed well known for varying very little with temperature fluctuations. It allows an audio system to run with ideal electronic conditions. This directly reduces overall noise in any electronic circuit, while establishing great operating conditions for other critical components.
The Vishay Dale CMF55 undergo strict quality control to achieve a measurement accuracy of 0.1 to 0.5% with a stability of 50 ppm/°C.
Designed with the highest level of electronic safety standards, these resistors have a flame retardant epoxy coating and excellent overall resistance to thermal stresses.
TypeResistance
Value1.21kΩ
Precision1%
Stability50ppm / ° C
maximum voltage250V
Maximum power1/2W
Insulation≥10^11Ω
Operating temperature-55 / + 175 ° C
Noise0.10 microvolts / Volt freq / 10yrs
Weight (max)0.20g
Materialsnickel-chromium alloy vacuum deposited
High purity ceramic
Flame retardant epoxy
Dimensionsø2.3 x 7mm
Resistance (Ohm)1210.0
Tolerance (%)1
Power (W)0.5
résistance
Réputation de la marque (qualité, précision).
Le composant qu'il faut pour respecter par exemple la courbe RIAA d'un préampli phono.
This review has been posted for VISHAY DALE CMF55 Resistor 1% 50ppm 1.21 KOhm
