RJ45 Connector Cat7 Shielded
New
This Cat7-standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable with a diameter between 5.8 and 8mm. Furthermore, to reduce any potential interference, this connector is shielded using a zinc alloy.
Reference : 20666
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 29-04-2025.
RJ45 Ethernet connector Cat7 Shielded Ø8mm
RJ45 connector : Front view
RJ45 connector : Dimensions
Product typeEthernet RJ45 male connector
Ethernet categoryCat 7
Min / Max cable diameter5.8mm - 8mm
Min / Max conductors section0.205mm² - 0.326mm² (22-24AWG)
Body materialPhosphor bronze
ShieldingNickel
Dimensions14 x 55 x 12.6mm
ColorSilver
PackageSold by unit
Max cable diameter (mm)8.0
Mounting typeTo connect
ConnecticMale
ConnectorRJ45
Contacts Material (Connector)Phosphor Bronze
RJ45 Ethernet Connector Cat7 Shielded Ø8mm
This Cat7-standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable with a...
