ELBAC 942545-S0 Ethernet RJ45 Cat6 Connector Simplified Assembly
4.9 / 5
Reference : 12107
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 22-04-2025.
ETHERNET RJ45 connector ELBAC
This Ethernet RJ45 connector will allow you to simply create your network cables. In fact, its simplified mounting system allows you to mount it on a suitable cable very quickly and with very few tools. Only cutting pliers and grippers are required for handling.
In addition, Cat 6 compatible, this one will allow you to reach, by using a cable of the same standard, excellent performance in terms of throughput. The connector is also backwards compatible with the cables of previous standards: Cat 5 and Cat 5e.
Find the video editing guide at the bottom of the page or download the product manual here .
TECHNICAL CHARACTERISTICS
  • Body Material: Allnickel plated zinc plated
  • Contact Material: Bronze Phosphor Plated Gold 50μm
  • Network performance: Category 6 / 6A
  • Cable Diameter Accepted: 6 to 9mm
  • Dielectric strength (1min / 60Hz):
    • Contact with contact: ≥ 1000V
    • Shielded contact: ≥ 1500V
  • Insulation resistance: ≥ 500MΩ
  • Contact resistance: ≤ 20 mΩ
  • Transmittable current: 1.5A max at 50 ° C
  • Contact resistance: ≥ 500MΩ
  • Permissible copper wire gauge: AWG26 to AWG22
  • Extraction insertion cycle: ≥ 750 cycles
Connecteur RJ45 Elbas Montage FacileCotations Connecteur RJ45 Elbac
Max cable diameter (mm)9.0
Mounting typeTo connect
ConnecticMale
ConnectorRJ45
8 reviews
très pratique
je confirme connecteur très pratique avec assemblage sans outil et de qualité pour du DIY dans mon avec câble CANARE RJC6-4P-SFM
c'est du sérieux !
This review has been posted for ELBAC 942545-S0 Ethernet RJ45 Cat6 Connector Simplified Assembly
Marche nickel
Parfait
Parfait
Très pratique
Lucien
Conforme à ma commande très bon produit
Connecteur rj45
Pratique, facile d'installation, j'ai pu connecter mes fils cat 6 à un switch.
Le débit est de 1G. C'est parfait.
