FURUTECH NCF CLEAR LINE LAN RJ45 Ethernet Signal Optimizer
This RJ45 connector from Furutech's NCF Clear Line range is designed to optimize the audio signal. It works in Plug & Play mode, and aims to improve the signal-to-noise ratio (SNR) and dynamics, for a more transparent sound. This NCF Clear Line RJ45 is dedicated to the Ethernet port of your devices. This optimization is made possible by the use of electrolytic capacitors and carefully selected non-magnetic materials.
By buying this product you get 27 loyalty points
Reference : 19351
270,00 €tax incl.
225,00 € tax excl.
Shipping date: 24-04-2025.
FURUTECH NCF CLEAR LINE LAN : Front view
FURUTECH NCF CLEAR LINE LAN : Electrolytic capacitor
Furutech Clear Line-LAN : Electrolytic capacitors
Furutech Clear Line LANs are equipped with electrolytic capacitors to enhance the performance of your devices. These are coated with a special high-performance damping treatment, eliminating unwanted vibrations. Interference from your devices' input and output terminals is also eliminated.
Furutech Clear Line-LAN : Alpha α treatment
All the metal parts that make up the Clear Line LAN benefit from the brand's two-stage Alpha α cryogenics and demagnetization process. First, the parts undergo deep cryogenic freezing via high-end refrigerants such as liquid nitrogen or helium. Once temperatures of between -196 and -250°C are reached, the parts are subjected to internal stress, tightening the molecules of which they are composed into tighter bonds, resulting in a more stable overall structure and improved conductivity. In a second step, the various mechanical parts are exposed to a ring demagnetization treatment patented by the brand.
Furutech Clear Line-LAN : High quality construction
The Clear Line-LAN's RJ45 connectors are covered with 24k gold-plated copper alloy EMI shielding, protecting them from oxidation and electromagnetic noise. Furthermore, the internal air chamber that receives the electrolytic capacitors is sealed under pressure for further damping effects.
FURUTECH NCF CLEAR LINE LAN : Descriptif des composants
The outer casing is made from non-magnetic stainless steel and a composite of carbon fibre and NCF (a crystalline material developed by Furutech). Finally, the NCF cover is made from a special heat-resistant nylon and Furutech's NCF material for improved efficiency and damping effect.
Product typeAudio signal optimizer
ConnectorRJ45
TechnologyNCF
Contacts treatmentα (Alpha)
Body materialStainless steel, nylon and carbon fiber
Contact platingCopper alloy and 24k gold
Package1x NCF CLEAR LINE LAN RJ45 Ethernet signal optimizer
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticMale
ConnectorRJ45
This RJ45 connector from Furutech's NCF Clear Line range is designed to optimize the audio signal. It works in Plug & Play mode, and aims...
