RJ45 Ethernet Connector Cat8 Shielded Ø8mm
This Cat8 standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable up to 8mm in diameter and has gold-plated contacts to provide foolproof resistance to oxidation. Furthermore, to reduce any potential interference, this connector is shielded using a zinc alloy.
Reference : 20669
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 08-05-2025.
Connecteur RJ45 : Front view
This Cat8 standard metal Ethernet J45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable up to 8mm in diameter and has gold-plated contacts to provide foolproof resistance to oxidation. Furthermore, to reduce any potential interference, this connector is shielded using a zinc alloy.
Product typeEthernet RJ45 male connector
Ethernet categoryCat 8
Max. cable diameterØ8mm
Min/max crosssection0.258mm² - 0.326mm² (23-24AWG)
Contact platingGold plated
ShieldingNickel
Dimensions13 x 42 x 13mm
ColorSilver
PackageSold by unit
Max cable diameter (mm)
  • 8.0
Mounting type
  • N/A
Connectic
  • Male
Connector
  • RJ45
Contacts Material (Connector)
  • N/A
Contacts Plating (Connector)
  • Gold
This Cat8 standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable up to 8mm...
