RJ45 Ethernet Connector Cat6 UTP Easy Mounting Ø9mm
This affordable RJ45 connector will allow you to assemble your own Ethernet cables without the need for special tools. It accepts cable diameters from 6mm to 9mm. The connector's transparent shell allows you to see the internal circuitry.
Reference : 16956
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 16-04-2025.
Connecteur RJ45
Cat.6 UTP Ø9mm
Connecteur RJ45 Cat.6 UTP Ø9mm
Product typeRJ45 connector
CategoryCat.6
ShieldingUTP
Min/Max cable diameterFrom 6mm to 9mm
Shell materialPlastic
ColorTransparent black
Max cable diameter (mm)9.0
Mounting typeN/A
ConnecticMale
ConnectorRJ45
This affordable RJ45 connector will allow you to assemble your own Ethernet cables without the need for special tools. It accepts cable diameters...
