TELEGARTNER AMJ CAT.8.1 High-End Ethernet RJ45 Plug Cat 8.1 Metal
This Ethernet Telegärtner AMJ plug in RJ45 format benefits from the brand new standard Cat 8.1. This last one will allow you to reach very high transmission rates, up to 40Gbit/s.
Reference : 14121
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 24-04-2025.
Telegärtner AMJ Cat 8.1
Embase RJ45 Ethernet Cat 8.1 High End Métal
Telegärtner AMJ Embase RJ45 Ethernet Cat 8.1 High End Métal
The connector, which complies with IEC60603-7 (RJ45 8P8C) standard, has a die-cast Zinc housing with 360° shielding to drastically limit the impact of external interference. The slim, extremely short and trapezoidal housing allows easy installation in all kinds of applications, ensuring perfect cable retention in the connector.
The plug can be combined with Cat 8.1 or Cat 8.2 cables with an external diameter of 6 to 10mm with conductors with a diameter of 1 to 1.6mm.
xxxxxxxxx
Dimensions de montage
xxx
Product typeFemale RJ45 plug
Ethernet categoryCat 8.1
Min / Max cable diameter6mm - 10mm
Min / Max conductor diameter1mm - 1.6mm
Connector standardIEC 60603-7 (RJ45 8P8C)
ShieldingCopper alloy
Min / Max temperature-40°C / +70°C
Power Over Ethernet Plus (PoE+)
Protection ratingsIP2X
IPX0
Housing materialZinc diecast Nickel plated
Total dimensions14.6 x 33.9 x 21.9mm
Max cable diameter (mm)10.0
Mounting typeTo connect
ConnecticFemale
ConnectorRJ45
Contacts Plating (Connector)N/A
This Ethernet Telegärtner AMJ plug in RJ45 format benefits from the brand new standard Cat 8.1. This last one will allow you to reach very...
