TELEGARTNER MFP8 CAT.8.1 T568B High-End Ethernet RJ45 Cat 8.1 Metal
This connector Ethernet in the format RJ45 takes advantage of the brand new standard Cat 8.1. This last one will allow you to design high quality cables, allowing you to reach very high transmission rates: up to 40Gbit/s.
Reference : 13720
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 22-04-2025.
Telegärtner MFP8 Cat.8.1 T568B
Connecteur RJ45 Ethernet Cat 8.1 High-End Métal
This connector Ethernet in the format RJ45 takes advantage of the brand new standard Cat 8.1. This last one will allow you to design high quality cables, allowing you to reach very high transmission rates: up to 40Gbit/s. The connector has a molded Zinc shielded body, allowing both to limit interference while ensuring perfect cable retention in the connector. The connector can be combined with Cat 8.1 or Cat 8.2 cables with an external diameter from 5.5mm to 10mm.
Here is a link concerning the T568A and T568B standards which will allow you to make the right choices for your network installation: T568A vs T568B
Product typeMale Ethernet RJ45 connector
Ethernet categoryCat 8.1
Connectors contacts platingOr
Min / Max cable diameter5.5mm - 10mm
Min / Max conductors sectionBraided conductor: 27AWG (0.102mm²) - 22AWG (0.326mm²)
Colid conductor : 24AWG (0.205mm²) - 22AWG (0.326mm²)
Min / Max conductors diameter1mm - 1.6mm
Poles number8P8C
Color codeT568B
Min / Max operating temperature-40°C / +85°C
Power Over Ethernet Plus (PoE+)Yes
Protection ratingIP20
Connector body materialZinc
Total dimensions56 x 16.2 x 14mm
ColorSilver
Max cable diameter (mm)10.0
Mounting typeTo connect
ConnecticMale
ConnectorRJ45
3 reviews
try this and you will buy this one more time.
This review has been posted for TELEGARTNER MFP8 CAT.8.1 T568B High-End Ethernet RJ45 Cat 8.1 Metal
Very good. you should try this.Nice product ,nice price.
Great product! Audiophonics Great Store! Everything is quick and to the point!
Thanks a lot!
This connector Ethernet in the format RJ45 takes advantage of the brand new standard Cat 8.1. This last one will allow you to design high quality...
