This connector Ethernet in the format RJ45 takes advantage of the brand new standard Cat 8.1. This last one will allow you to design high quality cables, allowing you to reach very high transmission rates: up to 40Gbit/s. The connector has a molded Zinc shielded body, allowing both to limit interference while ensuring perfect cable retention in the connector. The connector can be combined with Cat 8.1 or Cat 8.2 cables with an external diameter from 5.5mm to 10mm.
Here is a link concerning the T568A and T568B standards which will allow you to make the right choices for your network installation: T568A vs T568B
Product type | Male Ethernet RJ45 connector |
Ethernet category | Cat 8.1 |
Connectors contacts plating | Or |
Min / Max cable diameter | 5.5mm - 10mm |
Min / Max conductors section | Braided conductor: 27AWG (0.102mm²) - 22AWG (0.326mm²) Colid conductor : 24AWG (0.205mm²) - 22AWG (0.326mm²) |
Min / Max conductors diameter | 1mm - 1.6mm |
Poles number | 8P8C |
Color code | T568B |
Min / Max operating temperature | -40°C / +85°C |
Power Over Ethernet Plus (PoE+) | Yes |
Protection rating | IP20 |
Connector body material | Zinc |
Total dimensions | 56 x 16.2 x 14mm |
Color | Silver |
Max cable diameter (mm) |
Mounting type |
Connectic |
Connector |
Contacts Material (Connector) |
Contacts Plating (Connector) |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
KUN LIANG C.
KUN LIANG C.
